Author Topic: Donkey Kong acting goofy, pic included  (Read 5671 times)
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« on: January 20, 2014, 03:00:39 pm »
Alright guys, I turn to you to solve this one, since I am stumped!!!
Sarver Systems
Re: Donkey Kong acting goofy, pic included
« Reply #1 on: January 20, 2014, 03:03:32 pm »
The color and contrast are beautiful. My flash has drowned out most of the color, but as you can see, the left side of the screen is squished together into a single line down the left.
I didn't see any adjustments for horizontal settings.
It is a Nintendo chassis.
  • Last login:January 31, 2026, 02:08:03 pm
« Reply #2 on: January 20, 2014, 03:12:34 pm »
Cap kit
Sarver Systems
« Reply #3 on: January 20, 2014, 03:50:20 pm »
That's always the quick answer. I'm told this monitor is a bear to recap.
Is it possible just a single component needs replaced?
I'm just hoping to get it fixed without out replacing 25-50 components.
ed12
« Reply #4 on: January 20, 2014, 04:40:53 pm »
that would be a g07/g08
yes cap kit is in order,the short list comes with 10 caps
but u need a coupler cap in there >size<
ed
« Reply #5 on: January 20, 2014, 05:04:31 pm »
As usual, ignore ed12.
It's a Sanyo 20EZ.  They're such pieces of crap to repair I rode along with a guy yesterday to go buy a fully working one instead of repair his old one.
Doubtless there's only one cap that needs replacing but nobody's documented what each one of them does.
Break out the soldering iron.
Sarver Systems
« Reply #6 on: January 20, 2014, 05:36:17 pm »
I'm just going to bite the bullet and do them all. I'm going to skip the flyback on this one, since the picture is already so beautiful and full of color.
Before I order anything, I plan to get the exact numbers off the chassis. That's the last thing I want to do is buy parts from Bob Roberts for the wrong parts.
ed12
« Reply #7 on: January 20, 2014, 09:56:18 pm »
pbj go back into your hole please and thk-u
btw it is a non-polar cap
ed
Sarver Systems
« Reply #8 on: January 21, 2014, 09:07:06 am »
It doesn't matter to me which one of you is correct on the model number, since I'll be checking it for myself anyways.
The point of my question was, if I needed a cap kit or not.
ed12
« Reply #9 on: January 21, 2014, 12:20:35 pm »
the non-polar cap as a rule dose not come in the cap kit
but by all means cap that baby..wont hurt
and well u are under the hood see if u can find the non  polar cap
it will look like a electrolytic cap,but if u look colse it will say by-polar
ed
the720k
  • Last login:July 04, 2019, 02:31:47 am
« Reply #10 on: January 21, 2014, 11:40:51 pm »
Looks very similar to an issue that had been happening on my 25K5501.  In my case, the vertical size was wrong due to a bad cap, and later an incorrect cap until I found out what kind of animal my chassis really was.  Replacing with a good cap of the correct value sorted it all out.
I'd listen to these guys and perform the recap.  Pay close attention to the vertical circuit and look for cold solder joints while you're at it.
My Machines:  Sega Top Skater | Vertical 25" JAMMA cabinet (Raiden Fighters II / 60-in-1 currently) |  Xevious (Restored)  |  3-Player MAME in a previously MA(i)MEd Beast Busters cab (In progress)  |  19" upright 2-player MAME cab w/light gun  |  Pac-Man Cocktail running MAME (built from scratch - no original harmed in the making) : http://forum.arcadecontrols.com/index.php?topic=64599.0
buffett
  • Last login:December 13, 2016, 01:28:10 am
« Reply #11 on: January 22, 2014, 01:48:35 am »
if you are in the US and need it repaired i can do it for you.
i also stock cap kits for the Sanyo and others.
a Sanyo is the absolute best 19" monitor you can have in a game.
i wish i could put one in every 19" game i have but i have to many for that to happen.
if you have any questions email me from my website.
thearcadebuffett.com
Peace
Buffett
Come to MAGfest and game in the 24-7 arcade for 4 days. www.magfest.org  And see my collection of 90+ Arcades and growing.
Need your (K7000, 4900, std/med res 13"-25") or Sanyo fixed!!!! pm me.
Visit my website. www.thearcadebuffett.com For Monitor and PCB repairs.
Fully rebuilt chassis ready to ship. Trade'ins welcome
I have met --- Tim McVey --- world nibbler champion and many of you have not.
Sarver Systems
« Reply #12 on: January 22, 2014, 09:04:36 am »
Peace
Buffett
What would the capkit cost from you?
« Last Edit: January 22, 2014, 03:26:14 pm by Sarver Systems »
buffett
« Reply #13 on: January 22, 2014, 03:07:51 pm »
send me an email.
my email address is on my site.
Peace
Buffett
Sarver Systems
« Reply #14 on: January 22, 2014, 03:31:14 pm »
Email sent.
Sarver Systems
« Reply #15 on: February 02, 2014, 02:49:10 am »
I received my capkit from Bob Roberts.
I'll be recapping it shortly.
In the meantime, I decided to make myself a little tool to make things quite a bit easier on myself.
Sarver Systems
« Reply #16 on: February 02, 2014, 02:50:53 am »
I drew it up in Excel real quick, laminated it, and glued it to a piece of foamcore. Let the glue dry, then punched holes through it with a paper punch. After that I found an old plastic container to act as a pedestal, and used Velcro to hold it on.
To use it, I just use wet-erase markers, fill in the blanks, and have at it!
Sarver Systems
« Reply #17 on: February 02, 2014, 02:52:42 am »
I made myself a quick little manual too, from websites, and other tutorials.
mgb
  • North East, US
« Reply #18 on: February 02, 2014, 01:39:24 pm »
Yeah, it always is best to setup your caps like that for easy identification while installing.
Remember to verify and set your B+ voltage when done.
Should be 108 volts.
Also, there may be a regular looking plug end on that monitor but don't plug into a regular outlet.
Sarver Systems
« Reply #19 on: February 02, 2014, 03:51:16 pm »
I will NEVER plug it directly into a wall outlet. I won't do that with ANY monitor.
Thanks for the heads-up.
mgb
  • North East, US
« Reply #20 on: February 02, 2014, 05:18:51 pm »
I didn't really figure you would but its always worth mentioning becauae I have seen others post, asking about that.
Not sure if you found it or not but there is a troubleshooting flow hart for that monitor. It's on klov. I think Buffett may be the one who made it.
Also be careful when adjusting the b+ because the adjustment pot is kinda delicate. I usually change out the pot when working in them. Bob Roberts has them.
buffett
« Reply #21 on: February 02, 2014, 05:24:37 pm »
sorry i did not make the flowchart on the Sanyo.
but you can use my video to help you adjust your chassis after you do the work on it.
Peace
Buffett
Sarver Systems
« Reply #22 on: February 02, 2014, 05:33:10 pm »
I don't have an acct on KLOV yet. Can you provide the link?
buffett
« Reply #23 on: February 02, 2014, 05:39:32 pm »
you may or may not be able to view this link.
http://i291.photobucket.com/albums/ll282/dokert/Monitor%20ID/Sanyo20EZVFlowChart.jpg
Peace
Buffett
Sarver Systems
« Reply #24 on: February 02, 2014, 05:57:31 pm »
It turns out I do have an acct there, but I have no idea what my password is, and the forgotten password regfistration is currently shut off.
Regardless, I was able to see the link.
Thank you!
mgb
  • North East, US
« Reply #25 on: February 02, 2014, 06:12:56 pm »
That's right, it was Dokert who posted it.
dcninja
  • Last login:March 01, 2025, 09:59:52 am
« Reply #26 on: February 08, 2014, 02:17:32 pm »
not to hijack the thread, but buffet? the arcade at magfest is your games?
buffett
« Reply #27 on: February 09, 2014, 03:27:01 am »
yes 80+ of them are mine that were there.
Peace
Buffett
