Author Topic: .  (Read 61023 times)
Re: Simplistic Pac-Man Bartop (Project Code Name: Yellow Fever)
« Reply #80 on: March 26, 2014, 01:08:00 am »
Awww, another weecade clone...  I still like my idea of the bartop that mimics the Pacman Battle Royale stand-up cabinet:
  :lol
ChanceKJ
« Reply #81 on: March 26, 2014, 01:11:23 am »
« Last Edit: March 18, 2021, 11:44:29 pm by ChanceKJ »
ChanceKJ
« Reply #82 on: March 26, 2014, 01:37:06 am »
« Last Edit: March 18, 2021, 11:44:35 pm by ChanceKJ »
  • Last login:Yesterday at 11:35:55 pm
« Reply #83 on: March 26, 2014, 02:31:11 am »
So pretty much test for current and if it's below what the USB gives off we're good to go?
That would be a great piece of info for anyone planning on using one in a build.
ChanceKJ
« Reply #84 on: March 26, 2014, 03:07:14 am »
« Last Edit: March 18, 2021, 11:44:40 pm by ChanceKJ »
ChanceKJ
« Reply #85 on: March 26, 2014, 03:07:59 am »
I don't get a reading on mA, i'm guessing the fuse on my meter is blown?
« Reply #86 on: March 26, 2014, 03:20:47 am »
Umm. . . Did you move the red lead to the center connector?
jdbailey1206
« Reply #87 on: March 26, 2014, 09:28:03 am »
:applaud:  Nice, hadn't even thought to look for an online database of files.   Ok, well with my limited (very limited) sketchup skills, heres what i was thinking...
I didn't have the time to add in the glowing red neon "Namco" logo. but you get the basic idea. A couple volume up/down buttons for the TV. Probably run the wood grain for the side panels vertically rather then horizontally shown in the pictures.  Dark tinted glass for both the Marquee and display.  Maybe a switch on the back for power, and one separate one for the neon logo?  Without a computer and with such a thin LCD panel i'm going to have a ton of room left over too.
This is all just a theoretical plan. May change in time.
Yeah.  Don't sully this awesome project with a weecade shell.  I built mine and I'm now in the process of gutting it for a Star Wars cab.  If you are doing a weecade you might as well go this route.
« Last Edit: March 26, 2014, 09:51:41 am by jdbailey1206 »
  • Last login:Yesterday at 11:47:17 pm
« Reply #88 on: March 26, 2014, 10:00:16 am »
I think something similar to Haruman's midway vert would work well. But a standard Weecade design? naw.
ChanceKJ
« Reply #89 on: March 26, 2014, 10:56:09 am »
« Last Edit: March 18, 2021, 11:44:49 pm by ChanceKJ »
  • Last login:Yesterday at 11:24:50 pm
« Reply #90 on: March 26, 2014, 11:01:53 am »
I'm not sure I'd go hardwood for a Pac-centric build. Cabs from that era were bright and colorful. I think something like that would be right up your alley and would work nicely. Your hardwood design would probably fit a Western-themed cab nicely, or maybe a Tapper.  :dunno
jdbailey1206
« Reply #91 on: March 26, 2014, 11:02:19 am »
In all seriousness if you want to do a bartop it would be nice to see a Pac Man shaped cabinet with the bottom half cut off.
« Reply #92 on: March 26, 2014, 11:29:29 am »
*sigh*
I didnt say to use a weecade, I didnt saying using one was bad. I didnt say to buy a kit from Haruman or Rick or anything. What I said was, make it in the shape of his Midway inspired vert. Mostly because his vert is based on a Pacman cab and you're making a mini one. His proportions are already scaled down and should be easier to go off of.
I digress.
ChanceKJ
« Reply #93 on: March 26, 2014, 11:32:55 am »
« Last Edit: March 18, 2021, 11:44:57 pm by ChanceKJ »
JDFan
  • Last login:June 01, 2024, 11:31:20 pm
« Reply #94 on: March 26, 2014, 11:33:46 am »
Kind of like this one made by Well Fed Games a couple years back :
« Reply #95 on: March 26, 2014, 12:18:32 pm »
Yep, went back and forth a couple times and even read the manual. Just reads zero.   :dunno
That certainly does sound like a blown fuse.
At least you can tell that it draws about 60 mA (0.06 A) while using the 10A range setting based on the earlier photo.
ChanceKJ
« Reply #96 on: March 26, 2014, 12:21:58 pm »
« Last Edit: March 18, 2021, 11:45:04 pm by ChanceKJ »
Well Fed Games
  • Last login:March 06, 2022, 07:30:46 pm
  • Delicious!
« Reply #97 on: March 26, 2014, 05:18:04 pm »
Which was based on the Brian Bishop bartop plans found here, FYI: http://vectorlib2.free.fr/Plans/
Of course my cab had to accommodate a CRT monitor.
ChanceKJ: Any chance for a pic of the pac boards with all the pins labeled? Looks like you are most of the way there already.
« Last Edit: March 26, 2014, 05:20:58 pm by Well Fed Games »
hsr
  • Last login:January 08, 2023, 10:46:34 pm
    • My Robotron Mame Cabinet
« Reply #98 on: March 26, 2014, 06:12:08 pm »
FOr anyone looking for one of these it seems Kmart got a new supply of inventory of these and the Space invaders units -- $24.99 for the Pacman 12 game unit and $21.99 for the 10 game Space Invaders unit !
Made a trip to the local Kmart and they had about 10 of the pacman and 12 space invaders in the store so will probably be picking one up this week. Since I found an old AC plug that is 6V 200ma output that should work fine to replace the batteries and have an old 13" TV sitting in the closet that has the proper inputs so looks like a good start for building something (perhaps a Dig Dug based bartop)  :applaud:
Thanks for this.  I picked one up on my way home today.  Surprisingly, I had a bunch of Shop Your Way rewards built up that I didn't even know existed, so got it for free.
Jeff
hsr
« Reply #99 on: March 26, 2014, 06:14:27 pm »
Anyone thought about one of THESE to trim down the voltage on a 6-12v cheapo phone charger?
Jeff
ChanceKJ
« Reply #100 on: March 26, 2014, 06:24:17 pm »
« Last Edit: March 18, 2021, 11:45:09 pm by ChanceKJ »
ChanceKJ
« Reply #101 on: March 26, 2014, 06:25:39 pm »
« Last Edit: March 18, 2021, 11:45:14 pm by ChanceKJ »
hsr
« Reply #102 on: March 26, 2014, 06:50:12 pm »
Screw the regulator. Do what I did and build a USB tap. So happy with that!
I like that idea, but the TV I picked up off Craigslist today doesn't have USB...  Samsung SyncMaster 710MP
« Last Edit: March 26, 2014, 06:51:43 pm by hsr »
Jeff
JDFan
« Reply #103 on: March 26, 2014, 07:28:17 pm »
Glad to help -- also stopped and picked mine up on the way home today ! :applaud:
Could get a cheap 5V 1a USb plug for less than $2.59 shipped to plug into a power strip ( http://www.newegg.com/Product/Product.aspx?Item=9SIA1340TA6297 )
« Last Edit: March 26, 2014, 07:32:25 pm by JDFan »
ChanceKJ
« Reply #104 on: March 26, 2014, 11:26:49 pm »
« Last Edit: March 18, 2021, 11:45:20 pm by ChanceKJ »
ChanceKJ
« Reply #105 on: March 26, 2014, 11:48:54 pm »
« Last Edit: March 18, 2021, 11:45:24 pm by ChanceKJ »
ChanceKJ
« Reply #106 on: March 27, 2014, 12:18:33 am »
« Last Edit: March 18, 2021, 11:45:28 pm by ChanceKJ »
« Reply #107 on: March 27, 2014, 07:39:29 am »
/Waits for Scott to chime in and call me crazy...  ???
You're crazy. :P
orion
« Reply #108 on: March 27, 2014, 10:14:12 am »
Lol! At the very least you have inspired me to root though a lot of old junk I have around the house. I should have an old Wico 4 way joystick around here somewhere...
Following with great interest!
ChanceKJ
« Reply #109 on: March 27, 2014, 10:49:54 am »
« Last Edit: March 18, 2021, 11:45:33 pm by ChanceKJ »
Well Fed Games
  • Delicious!
« Reply #110 on: March 27, 2014, 12:30:29 pm »
Does this help?  All the important ones are labeled, except for the buttons on the bottom right, but thats just A, B, and a common ground.
Yeah, that's great. For some reason I expected it to be more complicated.  :laugh: Thanks.
  • Last login:Yesterday at 02:21:48 pm
« Reply #111 on: March 27, 2014, 01:02:22 pm »
When did it become popular to be sick of Weecades? Welcome to like 4 years ago, BYOAC.
Those TV joysticks sure have improved....
404
« Reply #112 on: March 27, 2014, 06:01:56 pm »
I have both the standard and deluxe models of the larger flashback units. The deluxe has some really awesome posters that would make great cabinet side art.
the pac and spacer invader units have already emulated surprisingly well considering the limitations of the hardware and standard televisions.
ChanceKJ
« Reply #113 on: March 28, 2014, 05:02:56 am »
« Last Edit: March 18, 2021, 11:45:39 pm by ChanceKJ »
JDFan
« Reply #114 on: March 28, 2014, 10:52:17 am »
Well, this is good news....
Looks like if I want to use a particular surface transducer that I had in mind it will replace these speakers perfectly! This cab will be so simple it won't even have speakers.  Well, conventional speakers anyway.  ;D
The transducers are like $21+shipping. So I'm gonna get just one, unhook both speakers from the TV and adjust the audio in the TV to only work out of the one channel that the transducer is connected too. I mean, the PnP only has mono audio anyways, why not cut costs?!
So spending $21 + shipping rather than using the speakers that the TV already has to cut costs   :dizzy:
Just kidding with ya - would be interesting to see what it winds up sounding like with that type of set up.
Unfortunately I didn't have much luck with the cost cutting effort -- had planned on using a 13" TV I had sitting in a closet (old Disney princess TV the niece out grew ) but the manufacturer in it's wisdom didn't put  TV\AV mode switch on the unit just on the remote and also made it switch back to TV mode every time power is turned off - So you have to change to AV mode every time you turn the unit off - I figured out a way to change it to AV without the remote but it is by pressing the power button after turning it on to cycle through the modes and is not completely reliable (if you press to long it shuts off rather than switching modes  :angry: ) - So looks like I'll have to source a different TV to use (hopefully the local Goodwill will have something) as I have a feeling using that one would cause more frustration than it's worth.
On the Plus side the 6v 250ma power adapter that was sitting in a box works fine to bypass the batteries for the PNP unit - so it's not all bad news at least.
« Reply #115 on: March 28, 2014, 10:57:14 am »
HAHAHAHA! I was thinking the same exact thing but didn't want to be "That Guy"!  :afro:
I've never seen a transducer in action, so it'll be interesting.
ChanceKJ
« Reply #116 on: March 28, 2014, 11:02:47 am »
« Last Edit: March 18, 2021, 11:45:45 pm by ChanceKJ »
ChanceKJ
« Reply #117 on: March 28, 2014, 11:08:21 am »
« Last Edit: March 18, 2021, 11:46:02 pm by ChanceKJ »
« Reply #118 on: March 28, 2014, 11:14:09 am »
I interned at a transducer company in the 90s (which meant I sat in the corner) and I still have no idea what the hell those things actually did.  They kept telling me "sense vibration in airplane engines."  All I really figured out was it was yet another company that got raw goods duty free, slapped them around a bit, and sent them to the mainland as American.
 :dunno
ChanceKJ
« Reply #119 on: March 28, 2014, 11:20:57 am »
« Last Edit: March 18, 2021, 11:46:08 pm by ChanceKJ »
