Author Topic: Android Quad Core, 4/8 switchable stick, Kade, Bluetooth keyboard and MORE!!!  (Read 1176 times)
Maximus
  • Last login:May 26, 2017, 05:32:05 pm
  • Plans are for fools!!!!
    • Arcade Icons
Hi guys,
I've got too many projects, so I figured I'd sell off some of my goodies including this kit I put together to build an Android based MAME rig.
I'd like to try and sell this as a bundle to keep it simple, please don't ask to split at his point.
$160 Shipped Domestic US States
Ultimarc Top Switchable 4/8 way stick - unused
KADE Encoder
ZD Enconder with wiring and USB/PS3 converter cable
Mini HDMI to VGA converter with breakout Audio line
iPazzport Bluetooth keyboard/mousepad - rechargeable with mini USB charger (included)
Tronsmart A9 Quad Core Android Stick
- OS: Google Android 4.1 (Flash 11.X: HTML5)
- CPU: Rk3188 Quad Core 1.6ghz, max 1.8Ghz(maximum data from manufacturer for CPU - only) (Cortex-A9)
- GPU: Quad Core Mali 400
- RAM: DDR3 2GB; ROM: On board NAND Flash 8G (Android system itself and other user data will take some space)
- Expand Micro SD: Micro SD Card/ T-Flash(Maximum support 32GB)
- Video Format: WMV/ASF/MP4/3GP/3G2M4V/AVI/MJPEG/RV10/DivX/VC-1/MPEG-2/MPEG-4/H.263/H.264/1280*720P HD 30 fps, 1080P/720*480 D1 30fps
- Audio Format: Support: MP3/WMA/APE/FLAC/AAC/OGG/AC3/WAV
- Picture Format: Support: Max.8000x8000 JPEG BMP GIF PNG
- WIFI: support 802.11 b/g/n
- Bluetooth: Bluetooth v4.0
- Output: MINI HDMI Port
- Dimension: 88mm * 31.5mm * 15.8mm
- DC: 5V 2A
- Weight: <50g - Storage environment: -20°C--60°C, 10%--90% Humidity
Ports
- 1*Mini USB,Support OTG/HOST ( USB port RJ45)
- 1*standard USB
- 1*Mini USB For charging
- 1*TF card slot
- 1*Blue LED(When connect to power
Package Includes
- 1*Tronsmart MK908
- 1*charger
- 1*hdmi cable
- 1*micro usb cable
- 1*otg cable
- 1*user manual
