Author Topic: Possible to boot directly into HYperspin with WIn 7?  (Read 10269 times)
jgoucher12
  • Last login:December 13, 2017, 08:56:59 am
« on: November 30, 2012, 12:52:04 pm »
Thanks all
I do have a Win XP x64 i could use instead but I am just curios. Thanks
Generic Eric
Re: Possible to boot directly into HYperspin with WIn 7?
« Reply #1 on: November 30, 2012, 01:20:55 pm »
Hi.  This is discussed at length in the following threads.  Search the forum using Shell and Hyperspin as keywords.
http://forum.arcadecontrols.com/index.php/topic,113896.msg1209412.html#msg1209412
http://wiki.arcadecontrols.com/wiki/Hiding_Windows
I've done this once, and changed it back as I hadn't haven't finished configuring everything.  I would suggest this would be your finally step.
brad808
  • Last login:May 22, 2023, 08:18:15 pm
« Reply #2 on: November 30, 2012, 01:44:37 pm »
Just to add to this you can set programs to run on hyperspin exit. I have mine to run Windows explorer once hyperspin exits. That way if you need to tweak something it's easy. No need to revert anything.
You can setup an exit program in hyperhq
Sent from my Galaxy Nexus
