Author Topic: Groovy Arcade Linux Installation  (Read 7744 times)
processor
  • Last login:June 18, 2018, 04:04:27 am
« on: March 27, 2012, 05:28:14 am »
Hi,
I have a problem with the installation of Groovy Arcade Linux 32bit.
I don't have any display of the installation. (the lcd pop up an error of display)
Does everything is in 15khz, even the installation menu?
--Processor
Ansa89
  • Last login:December 09, 2016, 10:40:11 am
Re: Groovy Arcade Linux Installation
« Reply #1 on: March 27, 2012, 07:45:03 am »
Did you select the right option at boot menu?
Earth could be the hell of another world
processor
« Reply #2 on: March 27, 2012, 09:28:26 am »
In fact, I was even not able to choose anything, straith to black screen.
But I found where was the problem. Iso to USB pen was not working correctly.
So I just burned on a CD and it worked
--Processor
Ansa89
« Reply #3 on: March 27, 2012, 09:30:44 am »
Report that issue to ves (eventually with other marginal info).
Calamity
  • Moderator
  • Last login:Yesterday at 04:18:09 am
  • Quote me with care
« Reply #4 on: March 27, 2012, 10:12:03 am »
In order to boot as live from a usb disk you need to download the right GroovyUSB... file and unzip it over the root directory of the usb disk where you have burnt the iso:
http://forum.arcadecontrols.com/index.php?topic=117334.msg1261471#msg1261471
Also, you have to rename the pendrive as GROOVY.
Steps to create a log:
Ansa89
« Reply #5 on: March 27, 2012, 10:30:45 am »
@Calamity: what about (you and/or ves) make a thread with a specific (and accurate) guide on how to make a bootable groovyarcade usb stick?
Calamity
  • Moderator
« Reply #6 on: March 27, 2012, 10:42:05 am »
Yes, I had that in mind, but first I need to figure out how to fix my usb installation :)
There are two different possibilities:
- Burn the live-cd to an usb pendrive (you need an specific program to burn the iso and the files I mentioned above).
- Install GroovyArcade to an usb pendrive. This is the cool way.
I got the installation to usb working with the gentoo based cd but I'm having problems now with the Arch-Linux build. Basically I'm getting an error on boot "unable to find root device ...". I've tried by changing the grub line from "root=/dev/disk/by-label/GA" to any combination of /dev/sdX but can't get it working. I don't know if it might have something to do with this (bottom of the page):
https://wiki.archlinux.org/index.php/Pacman#Q:_I_get_an_error_when_updating:_.22file_exists_in_filesystem.22.21
Ansa89
« Reply #7 on: March 27, 2012, 11:01:50 am »
Ok, this could help (even if it was written for slackware).
The main problem is that it's written in italian language.
ves
  • Last login:April 11, 2020, 02:57:49 am
« Reply #8 on: March 27, 2012, 01:05:35 pm »
Hello, the problem is missing a hook to generate the kernel, is fixed in the next version, while you can use these files.
Remember only when installed in a pendrive.
File name: kernel para usb.rar File size: 19.22 MB
Calamity
  • Moderator
« Reply #9 on: March 28, 2012, 05:21:04 pm »
Thanks Ves, those files fixed my pendrive installation.
I've used this great tool to access the pendrive Ext3 filesystem from Windows: http://www.fs-driver.org/
