Author Topic: Groovymame + arcadevga v2(HD2400) + drivers calamity??  (Read 2736 times)
scatoons
  • Newbie
  • Last login:January 27, 2012, 12:45:54 am
« on: January 27, 2012, 12:44:43 am »
Hi Calamity,
I post here because I haven't seen my problem elsewhere :
I would have liked to try your drivers on a configuration based on ArcadeVGA2 HD2400 (WinXP32).
After having properly uninstalled the Ultimarc driver, I installed your driver "crt_emudriver_9.3_1.2a_xp32_multisync".
Then, the executing of Arcade_OSD indicate "crt_emudriver not found".
Indeed, by checking the properties of the GPU, I notice the card didn't start because there is a code 10 error.
Are you informed about incompatibility between your drivers and those HD2400 from Ultimarc?
Does there exist a particular procedure with these GPU?
If that can be useful to you, here is a screenshot of this HD2400 device ID:
Thanks in advance for your assistance.
Bye
Calamity
  • Moderator
  • Last login:April 10, 2024, 02:02:31 pm
  • Quote me with care
Re: Groovymame + arcadevga v2(HD2400) + drivers calamity??
« Reply #1 on: January 27, 2012, 05:09:36 am »
Hi scatoons,
Unfortunately, there's no support for ArcadeVGA cards based on HD2400 chipsets or above. Just the old Radeon 9250 and possibly X300 and X600 based cards are supported.
Steps to create a log:
