Author Topic: Help please - my tron mala theme  (Read 4112 times)
wol-nz
« on: September 07, 2011, 10:17:36 pm »
Hey all - I've been working on my tron art work [BTW can be downloaded in the art section]
http://forum.arcadecontrols.com/index.php?topic=113679.msg1207156#msg1207156
I'm a new comer to the mala theme builder but i think i have a good grasp of it.
One issue i can't resolve is the transparency edge issue.
Notice the blue outline around my snap portal is blue. Funny thing is the transparent function requires a colour to transparent.
My first choice was black - but the edge turned white (way to obvious) so i've gone blue (as that looks a bit better)
The best would be to have no outline.
Any ideas. cheers
Re: Help please - my tron mala theme
« Reply #1 on: September 07, 2011, 11:18:08 pm »
Yeah, Mala transparency kinda stinks. It supports PNG, but not the alpha channel, so you can't have smoothly faded transparencies, which means you'll always end up with jaggies on rounded (or non-square) masks.
I'm actually trying to come up with a solution for that in Engine18 (an addin for Mala I've been working on), but haven't quite got all the kinks worked out yet.
Love that layout though. That kind of layout would work well with my slideshow plugin (basically, it rotates through various images associated with a particular rom with a little animated fades for good measure).
I'm not quite done with  that either though. Pesky things like a job keep getting in my way  :)
wol-nz
« Reply #2 on: September 07, 2011, 11:59:12 pm »
Cheers thanks for that - Yes sir `re those jaggies look awful. I thought i going to be clever and import a massive .gif then re-size it down with in the mala editor. HAHA that didn't work.
Unless i can find a way (excluding changing my background to white) i'm just going with this one.
empardopo
  • Last login:November 17, 2025, 01:32:25 am
    • My personal forum
« Reply #3 on: September 08, 2011, 10:10:10 am »
I like it and your avatar too!  :cheers:
TopJimmyCooks
« Reply #4 on: September 12, 2011, 10:00:25 am »
+1 on the 2nd layout.  Solves the problem/limitation with round snap/vid windows and looks great.  plus, people don't read what the game is in quite the same way with a round window view of it, as I found when i played with a similar theme.
wol-nz
Re: Help please - another question my tron mala theme
« Reply #5 on: September 12, 2011, 07:41:24 pm »
RESOLVED - there was a check box in options/configurations buried deep in.
GUI tab then Options tab then Gamelists/Misc tab
In there was Remove brackets from names (on the fly)
WOOT fixed it.
Thanks for that - another question i have...
See the game details in brackets Bomb Jack (set 1)
How do i get rid of the '(set 1)' bit.
I've clicked and toggled anything and everything in the mala interface but can't seem to change it. Maybe a no go'er?
Cheers
« Last Edit: September 12, 2011, 07:53:10 pm by WoLLiEnZ »
Celsius
  • Last login:May 10, 2015, 11:40:41 am
    • Rcade project
« Reply #6 on: September 13, 2011, 08:41:12 am »
use MalaGamelist.exe to remove all brackets   ;)
