Author Topic: FS - Williams NARC Cab for MAME, Multi-Board, JAMMA, etc. - Kentucky.  (Read 1910 times)
tta583
  • Last login:April 10, 2013, 11:06:34 pm
I have a very solid Williams NARC cab that it looks like I can spare.  It's very solid, no damage beyond usual nicks and scratches, no water damage, great bottom.  All the access panels are there.  None have missing or broken corners.  Even the lock holes are un-broken.  The cab would be great for a MAME setup or a Multi.  The factory control panel is huge..lot or real estate to do pretty much anything you want with no need to build a custom add on panel.  There is also quite a bit of space directly under to panel for hardware, interconnects, keyboards, wiring, JAMMA board if you go that route, etc..
It is designed for a Horizontal mount monitor.
The plastic monitor shroud is included.
The marquee brackets are included.
Coin door and vault are included.
The cabinet has 3 speakers. 2 mid/bass and a tweeter. Those are included with the cabinet.
Florescent light fixture in the marquee are is included.
The pictures show joysticks and buttons. Those are NOT included with the cabinet.
The NARC game boards and switching power supply will also be removed.
Looking to get $125.
I don't hang out here as much as I used to but will check back till I sell it.  It may be best to e-mail me with the address in my profile.
« Last Edit: July 13, 2011, 08:47:09 am by tta583 »
tta583
Still for sale.  Looking to free some space if someone is interested shoot an offer.
