I got some work done on my retro ports panel on Saturday. It's going to fit into the front piece of wood underneath the control panel, possibly hidden by some sort of flap/cover. I'm trying to keep the panel reasonably easy to remove in case I want to add additional ports in the future. Right now its got 1x NES, 2x SNES, 2x N64, 1x Gamecube, 1x Megadrive and a USB port for good measure
A GC/PS2/Xbox USB 3 in 1 "Magic Joy Box adapter" with the outer casing removed.
SNES adapter
N64 adapter
I de-soldered each of the ports (making a note of what goes where), then soldered wires on to each pin. I quickly learnt that the heat of the soldering iron can soften/melt the plastic and the pins will move if you let this happen. As a safety measure I kept a controller plugged in to each port to keep the pins in line
Making use of new favourite toy - my hot glue gun (all of my future projects will be built entirely out of hot glue)
All ports ready to be fitted
Starting to come together! I'm going to get all the cuts done, spray paint and then hot glue everything in place
