Has anybody gotten Mortal Kombat Trilogy (the PC game) to work correctly on Windows 7?
There seem to be two options out there, but both have their issues:
1. The installer for the XP patch version floating around on the web won't even install. If you simply tried to use the executable from a pre-install on Windows XP, it will run but crashes at the character selection screen. The patch works great on XP and the executable has to be run in Win 2000 compatibility mode. This trick does not help in Windows 7 (at least 64 bit). On Windows XP, this mod works great with music and everything.
2. The MKT Enhanced Edition 2.1 installs beautifully but it has a problem on both, XP and Windows 7. If you mount the disc image, you can have music in the game but due to a bug, the music turns off on the first fight. You can re-enable it by toggling music off and on from the menu bar, but it does not stay on consistently.
If anybody has gotten one of these to work perfectly with music and everything, please let me know.
