Author Topic: Jstick vs JLW UM-8?  (Read 1778 times)
Necro
  • Last login:December 31, 2025, 03:36:17 pm
Jstick vs JLW UM-8?
« on: April 26, 2011, 08:54:19 pm »
Quick question for anyone with a J-stick - whats actually on the screws that makes it able to be changed one handed?  Want to modify one of my JLW's to do the same thing.  It LOOKS just like a nylon washer, but wasn't sure.
SammyWI
Re: Jstick vs JLW UM-8?
« Reply #1 on: April 26, 2011, 09:13:31 pm »
It also has a spring between the washer and the head of the screw.  If you didn't already have the base stick, I'd say just get the J stick from Ultimark.  You'd probably spend less than experimenting with what washers, springs and maybe longer screws to use.  But good luck in your quest.
Necro
« Reply #2 on: April 26, 2011, 10:27:31 pm »
With shipping and all, it would have cost me too much more to order just the joys from Ultimarc and the buttons/other items from another store...so...went with the JLW's.  I've looked at them a bit more and I'm fairly certain I know what the setup is and can do it myself.  Just would like some feedback from someone that has a Jstick to see what is needed to facilitate the switching.
