Author Topic: My cabinet that has 873 control panels.  (Read 4329 times)
paigeoliver
  • Awesome face!
« on: August 20, 2003, 02:25:03 am »
Since I made a decision not to buy, accept, or retrieve any more cabinets, I am making my final cabinet a true monstrosity with an insane amount of swappable control panels.
I am using a generic video poker cabinet that does not use a marquee. The monitor will be horizontal, but can be flipped to vertical if I feel like opening the case and doing so.
So far I have completed the following panels.
Analog stick. Used a microsoft sidewinder 3D pro.
4-Way stick. - Ms. Pac/Galaga replacement stick, with two buttons.
The following panels still need to be made.
  • Lunar Lander panel. I am going to use the analog shifter from a cheapo PC wheel for this one.
  • Missile Command - Imperial PS2 trackball with 3 buttons.
  • Asteroids - I bought an NOS Willis Asteroids overlay to use for this one.
  • Tac/Scan or Tron - I am still waiting on my Tac/Scan panel to arrive. If it fits the machine, then I will use it as is. Otherwise the spinner comes off, and I will make a Tron panel using that spinner, and a Wico leaf switch top fire stick.
  • Stargate/Defender - Maybe I can get good at these games if I recreate the actual controls.
  • Directional gun - I have a single T2 gun on the way, and I already have a dual strike to interface it to.
  • Stepmania Panel - Simply going to recreate a 2 player Pump it Up setup with buttons on the control panel. Playing doubles at triple speed should still be challenging, even if you are using your fingers instead of your feet.
  • Steering wheel. I have a USB Nascar wheel that I am going to use. A panel will open up at the bottom of the cabinet for the pedals.
I already basically have all the parts for the above panels. Future possibilities might include a Star Wars panel, a Battlezone one, a 720 one, a 360 degree wheel panel, and a motorcycle panel.
I already posted some pictures of the first two panels in other threads. I will post more pictures as this stuff comes together. I still need to install the coin door onto the machine before I do anything else.
pathdoc2
  • Last login:January 11, 2006, 08:49:53 pm
  • Your friendly pathologist
Re:My cabinet that has 873 control panels.
« Reply #1 on: August 20, 2003, 10:08:26 am »
Post some pics, I want to see some of these control panels.
paigeoliver
  • Awesome face!
« Reply #2 on: August 20, 2003, 11:03:54 pm »
Oops, this machine might have to go on the back burner, I have a Battlezone coming. The Battlezone is going to get the monitor that was slated for this cabinet. So I am either going to have to step down to a smaller monitor, or wait until I get another 19-21" one.
« Last Edit: August 20, 2003, 11:17:40 pm by paigeoliver »
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #3 on: August 21, 2003, 12:16:34 am »
Uh, isn't Battlezone vector  ???
paigeoliver
  • Awesome face!
« Reply #4 on: August 21, 2003, 12:37:32 am »
Well, yeah a REAL Battlezone is vector. But a REAL Battlezone has actual Battlezone boards inside, and not a computer.
pathdoc2
« Reply #5 on: August 21, 2003, 09:36:32 am »
Man , I love Battlezone.  Great game.  What is the difference between a vector monitor and a regular one?  This is the first time I've heard the term vector used in reference to a monitor.
SirPeale
  • Green Mountain Man
« Reply #6 on: August 21, 2003, 09:56:53 am »
Raster monitors draw the picture line by line, starting at the top of the screen, and moving down.
Vector monitors draw JUST the lines.  Check out a vector game and you'll see what I'm talking about.
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
« Reply #7 on: August 21, 2003, 12:16:26 pm »
well, i guess this time will be good for you, you can get a bit more of start, after all, 873 cp dont build themselves :P
It's all about the Pentiums
paigeoliver
  • Awesome face!
« Reply #8 on: August 28, 2003, 07:18:44 am »
Just a brief update. My T2 gun has arrived and looks good. My Tac/Scan panel also recently arrived, and looks great, but it is too wide for the machine. So I will be pulling the spinner and buttons off and duplicating the panel at the appropriate size for the cabinet (anyone want a nice Tac/Scan panel without the controls?).
I won't be doing any actual work on this machine until I move (probably OCT 1st), as I really just want to get everything packed up. Plus, cabs are easier to move when they don't have monitors mounted in them yet.
I am also apparently getting an Exidy directional gun in a trade. I will probably just sit on that as a future trade item, since I already bought the T2 gun (Ironically enough, I bought the T2 gun to play the Exidy gun games).
