Author Topic: Mala not compatible with Project 64?  (Read 2338 times)
MagicManPA
  • Last login:January 12, 2019, 04:35:43 pm
« on: January 01, 2011, 03:06:19 pm »
When I try to open the ROM through Mala for Project 64 it will never work, but if I manually do it via Project 64 it works fine so the ROMs are good.
Every other emulator I'm using works fine. Just Project 64 has this issue.
Anyone else have this problem? Is there a fix for this?
thatgammon
  • Last login:July 03, 2020, 05:25:03 am
Re: Mala not compatible with Project 64?
« Reply #1 on: January 02, 2011, 06:57:16 am »
What instructions are in the command line for it?
MagicManPA
« Reply #2 on: January 02, 2011, 03:58:34 pm »
%path%\%rom%.%ext%
I added quotes & still no go.
thatgammon
« Reply #3 on: January 02, 2011, 04:03:34 pm »
no you have the right command line.
what exactly happens when you try to load a game (through mala)
any errrors?
