Author Topic: Mortal Kombat 2 resto  (Read 2006 times)
tonyh22
  • Last login:February 24, 2012, 06:35:42 am
« on: December 23, 2010, 06:07:43 pm »
I have just started my MK2 resto and I am working with the electronics first. I checked the power supply and adjusted the +5v to 5 but when I did it dropped my -5 to -3.6v or so. And my +12 is more in the +11 range. Does this signify I need a new power suply?
This is my first resto as you can tell with the noob questions.
Spyridon
Re: Mortal Kombat 2 resto
« Reply #1 on: January 03, 2011, 03:39:34 pm »
The +5v is the most important.  The +12v in the +11v range should be fine.  I'm not sure on the -3.6v if that is too low or not.  Is the game powering up?
MK3FAN
« Reply #2 on: January 26, 2011, 06:12:33 am »
The MK boards are VERY picky about the -5vdc. MK1 - MK4 need nearly EXACTLY -5vdc or you may have glitches. That's just my experience. It's always a good idea to go ahead and replace the power supply if you suspect it. They aren't that expensive.
