Author Topic: Ultrastick plugin works only for MAME?  (Read 2249 times)
Gray_Area
  • -Banned-
  • -Banned-
« on: September 29, 2010, 04:12:46 am »
Maps don't seem to be loaded for other emulators. Is it supposed to be this way?
-Banned-
arzoo
  • Robots WILL kill you.
    • LEDBlinky
Re: Ultrastick plugin works only for MAME?
« Reply #1 on: September 29, 2010, 07:46:04 am »
Only mame has data on which controls are used by each game (controls.ini and mame.xml). For other emus you may be able to specify a default 360 map - but I'm not sure how to do that for the plugin.
Robots will kill you.
Arcade Addiction
kegger
  • Last login:April 10, 2011, 10:59:14 am
  • There are no unsingable songs....
« Reply #2 on: October 04, 2010, 09:53:00 am »
Most other console systems use only 1 type of controller so in Mala under "other Emu Config" under pre commands you can use Ultramap to map a specific map for that system.
I find that making your sticks analog works for most systems or 8-way
Gray_Area
  • -Banned-
  • -Banned-
« Reply #3 on: October 06, 2010, 11:36:29 pm »
I don't have any issue with other emus, but for other MAMEs via 'other emulators'.
-Banned-
