Author Topic: Wanting to build a narrow, lit button interface  (Read 3329 times)
Dermbrian
  • Last login:January 19, 2024, 05:05:16 pm
« on: August 12, 2010, 02:52:52 pm »
I'm considering building a button controller for placement between my MSI all-in-one's PC keyboard and its 22 1/2" touchscreen monitor.  The background here is that I really like DWJukebox as a singles-based jukebox app, but it doesn't work with touchscreens except in Windows XP.
What I'd like to end up with...buttons all in a single straight line grouped as follows:
Letter keys (A B C D)
Number keys (1 2 3 4 5 6)
Select key
Left arrow
Right arrow
Coin button
I would very much prefer that all buttons be lighted, small enough to make this practical, and with insert areas where I could put those values into the button rather than a label near the button.  Total length of the button controller would have to be, at most, 21 inches.
Does anyone know a source of buttons that would make this practical?  Or have any advice as to how else I might make a standalone pushbutton controller like this?
I use the PC primarily for music, and really like the old-style singles interface that you can customize in DWJukebox.
Dermbrian
Re: Wanting to build a narrow, lit button interface
« Reply #1 on: August 12, 2010, 04:40:44 pm »
Here's what I'll do using standard arcade buttons if I can't find any good backlit solution.  Maybe backlight the legend strip....
With 14 buttons, I should be able to place them within 21 inches of linear space, right?
Brian
unclet
« Reply #2 on: August 15, 2010, 03:52:00 pm »
Groovy Game Gear (Randy) sells button inserts:
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=73&products_id=302
Perhaps ask Randy whether he would create custom inserts for you with the text you want it.  His description indicates they can be placed into a button which can be backlit as well.  If he does not offer custom inserts then I would see what you local copy or print store has available.
BobA
  • What Me Worry?
« Reply #3 on: August 16, 2010, 01:57:15 am »
You probably want smaller buttons then normal PBs.    Sort of like the ones used on the Dream Authentic Katana for jukebox functions.
Not sure if they are backlit.
« Last Edit: August 16, 2010, 09:11:24 am by BobA »
egosbar
  • Last login:May 17, 2014, 12:26:20 am
« Reply #4 on: August 20, 2010, 10:40:14 pm »
i went with a stainless momentary button with the numbers etched on them , they have a blue illuminated light but i havent built yet but they look very smart , they are pretty small about 15mm i think , if you interested i can give you the contact , i paid about 10 bucks a button with the etching included which was pretty good ,
they etching is nearly black i cant wait to hook em up
my biggest problem now is sk juke wont work with windows 7  and it was my primary jukebox for button support   :'(
and problem is im not that keen on any other juke (buttons supported)that ive tried and ive tried most now
