Author Topic: Problems running CHD games on my high end pc...  (Read 3130 times)
Rulkiewicz
  • Last login:October 22, 2010, 08:28:12 pm
« on: August 07, 2010, 11:35:17 pm »
I have:
Intel Core 2 2.2Ghz
3 GB of Ram
NVIDIA GTS 250 video card
When I play Blitz and some other games my sound and/or video is choppy... more noticeably my sound, it gets real echoy.  My rom sets and CHD's are .139, but I'm using MAME32 138, is it the differences in rom/mame versions which cause the choppyness, or is it that my PC isn't good enough, or that some particular CHD games don't work properly?
WhereEaglesDare
    • My HomePage
Re: Problems running CHD games on my high end pc...
« Reply #1 on: August 07, 2010, 11:49:31 pm »
I think that there is problems with Blitz.  How does it play Killer Instinct and Killer Instinct 2?
Rulkiewicz
« Reply #2 on: August 07, 2010, 11:51:18 pm »
Perfectly.
SlayerAlex
  • Last login:September 17, 2011, 09:19:27 pm
« Reply #3 on: August 08, 2010, 03:59:02 am »
3d intence games like Blitz and Gauntlet legends are the hardest to run. Mame is almost all Processor powered so You'll need at least 4Ghz to run those decently.
WhereEaglesDare
    • My HomePage
« Reply #4 on: August 08, 2010, 09:18:01 am »
Get a 3.2 GHZ P4 and a new heat sink and OC it to 4.  60 bucks and youre in business.
Haze
    • MAME Development Blog
« Reply #5 on: August 09, 2010, 12:44:46 pm »
I have:
Intel Core 2 2.2Ghz
3 GB of Ram
This isn't really a high-end PC, it's more mid-range by current standards.
64-bit build on a 64-bit version of Windows will give you the best results, but you're still looking to need in the 3.5ghz - 4ghz C2D region for these.
Ignore the other poster, a P4 clocked to even 4ghz won't cut it, and will only give you similar, if not significantly worse performance than you already have (these drivers make use of multiple cores, and a C2D gives much better performance per mhz than a P4 anyway, roughly twice as fast in some cases)
