Author Topic: "How to Set up Batch Files" in Maximus Arcade  (Read 37837 times)
  • Last login:June 24, 2025, 11:15:21 pm
« on: August 07, 2010, 01:10:34 am »
You can find a great batch file creation tutorial here:
http://www.computerhope.com/batch.htm
Follow the instructions under the Windows section (using Notepad to create).
However, there is an easier way to run PC games from MA.  It also eliminates the ugly command prompt box that pops up when using a normal batch file.  This is for Maximus Arcade version 2.10 Final only, where shortcuts have been fixed (previous version were broken)
Simply right click the .exe file for the game that you want to run and then in the context menu select "create shortcut". Then right click on the shortcut and select "Rename".  Whatever you rename it is how it will appear in the Maximus Arcade list.
Once that's all done, I make a directory in the MA folder called "batch files" and then drag all of your shortcuts you created there. Then in Preferences set that folder ("batch files") for the rom folder to scan. Make sure the # 3 option is selected after you set it to point to the right directory: http://www.maximusarcade.com/max.htm#scan (also make sure you have "batch files" selected in the dropdown above.)
I only create batch files if specific commands need to be run if the other method does not work properly. But 90% of the time you don't need to.
Hope this helped!
~ DeLuSioNaL29
« Last Edit: August 07, 2010, 01:13:31 am by DeLuSioNal29 »
jimmy2x2x
Re: "How to Set up Batch Files" in Maximus Arcade
« Reply #1 on: August 07, 2010, 01:38:17 am »
Very nice, cheers!  :cheers:
Bender
« Reply #2 on: August 07, 2010, 09:38:55 pm »
Dude! That is genious!!!!!!!
I just tried it out
no command prompt on load OR exit awesome!
Thanks once again D :applaud: :applaud:
nickynooch
  • Moderator
  • Last login:August 29, 2020, 02:54:00 am
« Reply #3 on: August 08, 2010, 05:13:33 pm »
I just tried it out
Ditto!  Finally got rid of the command prompt window.  Props delusional.
Ortizimo
  • Last login:July 10, 2024, 07:26:45 pm
  • USAF Retired Veteran (1995-2015)
« Reply #4 on: September 20, 2010, 08:49:39 pm »
Please excuse my ignorance but, why would I want this? What can I run in batch that could be useful. Thnx!
Sometimes, when it's quiet, I can still hear the monkeys." - Guybrush Threepwood, Mighty Pirate.
jimmy2x2x
« Reply #5 on: September 20, 2010, 09:01:44 pm »
PC games are an example
You make batchfiles or shortcuts in a new folder then point maximus to that folder and you have them ready to launch from the front end
Garza
  • Last login:July 09, 2015, 10:53:29 am
« Reply #6 on: October 21, 2010, 07:31:29 pm »
Wow thats kool!  :applaud: So I can take normal PC games i.e. NFL Blitz due to the Rom and CHD move to slow... I will be able to enter and play the pc game on the front end? I am just a little new to this and want to make sure I get it right! THanks
Yoeddy1
  • Last login:September 15, 2022, 12:40:23 am
« Reply #7 on: December 17, 2010, 03:04:59 am »
I set up NFL Blitz pc version, patched it, and set up in MA per D's instructions...works great!!!
However, when I enter the game, there are about 4 screens that I have to click ok through:
1.  The initial screen that contains options and the start button
2.  The window that states that "Triple Buffering worked ok."
3.  The window that lets you select resolution options.
I do this and everything plays fine, but is there a way that I can eliminate having to manually click ok on each of these screens that will just automatically rifle through them and start the game?
Thanks,
Jason
Trebeck
  • "The Arcade" - Build #4
« Reply #8 on: May 18, 2011, 12:12:04 am »
Wondering about this myself.  Can I just jump into ST4 without the Launch window?
MaseMan
  • Last login:May 04, 2025, 06:42:00 pm
« Reply #9 on: March 23, 2016, 03:11:38 pm »
Sorry to bump a very old thread, but I'm dealing with this same problem in MA with Street Fighter IV Ultra. I keep getting a message that "Steam must be running." I have tried creating a batch file using both MA's built in batch file maker, and also the method described in the OP of this thread (creating a shortcut). Either way, I still get the Steam error message. Steam is running, and the game launches fine directly from Steam. Anyone have any ideas on this? Thanks.
MaseMan
« Reply #10 on: March 25, 2016, 04:02:33 pm »
Never mind... I figured out there's a really simple fix. You just have to add ".exe" as valid file extension under MA's setting for Batch Files, and it works now!
