Author Topic: Need help running PC games in Maximus Arcade via batch files  (Read 8919 times)
t0mbi
  • Last login:October 20, 2010, 11:59:10 am
Sine the MA are down and have been for a week, can someone help me out please?
Im trying to get Street Fighter IV to run in MA.
I have it installed. Firstly, making batch files in the preferences of MA comes up with an error regarding media file location. So i pointed to a folder i named 'batch files'. Still no luck.
Can anyone tell me what im missing or direct me on an easier way?
Also, can i rename the Batch Files menu in MA to say "PC Games" at all?
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
Re: Need help running PC games in Maximus Arcade via batch files
« Reply #1 on: June 27, 2010, 05:44:00 am »
under the batch settings you need to set a batch folder, then you go to gamelist and under there there is a tab that says "batch".  Direct it to your sf4.exe and create a batch file (you just need to fill out the top part with the name) and that should work.
  • Last login:July 11, 2025, 09:17:44 am
« Reply #2 on: July 14, 2010, 01:01:23 pm »
And don't forget this guide to get it to work on an arcade machine that uses a keyboard encoder:
http://forum.arcadecontrols.com/index.php?topic=96377.0
Bender
« Reply #3 on: July 19, 2010, 01:02:41 pm »
Yes, but you have to change the Graphics in the theme Editor, so it's a bit of work cause you'd have to make new graphics to drop in (or wait till I make some, but I have no idea when that will happen)
It will still say batch files in the preferences pane (but no one ever sees that)
one day I will make new graphic for "PC Games" to replace the Batch files and I'll post em here
