Author Topic: 1/2 inch wood and T-molding Question  (Read 4921 times)
jmike
« on: May 03, 2010, 08:36:52 am »
Hi there.
    Was wondering if anyone could help me out. I'm in the process of building a 2-player fight stick using 2 hacked XBOX 360 controllers. I ordered happ buttons, joysticks and ordered the t-molding to fit 3/4 inch wood.
Since I got inspired with Super Street Fighter IV I thought I'd put some artwork on it so I went out and bought a piece of 1/4 plexi. My question is how hard would it be to make the slot for the T-molding on a 1/2 plywood? (You see it can't be centered since the plexi is 1/4 inch).
Or would it be easier to use 3/4 inch plywood and just shave off 1/4 of the bottom of the CP so the plexi is still covered by the T-molding.  I really don't want to order some more T-molding. ANy suggestions?
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
Re: 1/2 inch wood and T-molding Question
« Reply #1 on: May 03, 2010, 10:35:46 am »
get some 1/8" plexi instead...you definitely don't need quarter inch & that way you'll have more plywood to support the t-molding...
  • Last login:Yesterday at 01:44:17 pm
« Reply #2 on: May 03, 2010, 05:43:03 pm »
Also, if you use the 1/8 plexi, you can use a razor (and steady hand) to trim the t-molding down a bit.
jmike
« Reply #3 on: May 04, 2010, 07:54:12 am »
      Thanks for the suggestions. I'll post a pic before I give it a go. Funny thing is I'll have the same issue with the bartop's CP I'm building.
bratwurst
  • Last login:July 03, 2021, 10:51:34 am
« Reply #4 on: June 01, 2010, 11:50:19 pm »
I have a similar issue, want to use the 3/4 t-mold I have on my control panel, and I already have 3/4 t-mold.  Doesn't someone sell offset t-molding for this case?
jmike
« Reply #5 on: June 02, 2010, 07:55:23 am »
I read on a different post that you can bevel the bottom of the control panel, this should allow you to raise the t-molding enough to cover the plexi. I didn't save the link (:angry:) where I read this but I did print out an image. (sorry it's black and white). I'll be giving this a try later this week when I have some free time so I'll post pics then.
dawolv
  • Last login:March 25, 2016, 08:23:21 am
« Reply #6 on: June 02, 2010, 09:47:13 am »
It was on Mountains Build Thread   ;)
jmike
« Reply #7 on: June 02, 2010, 10:11:01 am »
That's the one.
Thanks dawolv,   :cheers:
