Author Topic: MALA, instant sheller :: Mala.exe DLL initialization failure at shutdown time  (Read 3163 times)
zorg
I was palying with a new configuration and once everything was set up I gave a try to instantsheller ( I'm lazy, I prefer some clicks instead of playing with reg db ;-) )
everything is ok except one point.
cab boots straigth to mala, everything works but when I exit mala (key combo on teh panel) as I've set up mala exit to shutdown,  I have the following error message.
Mala.exe DLL Initialization Failed -
The application failed to initialize because the window station is shutting down.
in te same time mala seems to starts again, as I see the layout appers again,  and then the machin shutdown.
any idea ??
I'm on the planning stage
loadman
  • Moderator
    • MaLa
Yes why would windows be trying to start MaLa again?
