Main > Project Announcements
New pinball table build: PIN-o-RAMA - 40/28/12
Pages: << < (7/18) > >>
bigpete405:
Looking good :applaud:. I can't wait to see more pics of the building process. :cheers:
IG-88:
--- Quote from: javeryh on February 13, 2010, 08:05:02 am --- .....Once you get the hang of it you can make very accurate cuts very fast.
Even tho you have to essentially make the same cut twice?
skepticalgeek:
SERIOUSLY impressive! Would you consider posting the woodworking plans and instructions online once you are done and get the kinks worked out? While I have neither the skills, tools or inclination for that, I have friends woho do and can be bribed with pizza and booze.
javeryh:
--- Quote from: IG-88 on February 13, 2010, 01:28:06 pm ---
Oh definitely.  It's not even close - the rough cut with the jigsaw takes seconds, it takes about 30 seconds to line up and clamp down the straightedge to the line and then less than a minute to trim it flush if you are going slow.  The hardest part is the layout.  You also never have to worry about missing your cut - if the straightedge is on the line and where you want it to be the cut will be perfect every time.
IG-88:
I like that idea too. I'll have to try it out.
Go to full version
