Author Topic: COnvergence  (Read 1551 times)
speedklz
  • Last login:November 17, 2018, 12:56:23 pm
COnvergence
« on: November 13, 2009, 02:39:19 pm »
Convergence is off on my wg25k7100 which rings adjust the green?
Best of the Best of the Best. Sir!
Kevin Mullins
    • Me on Myspace
Re: COnvergence
« Reply #1 on: November 13, 2009, 03:50:01 pm »
Grab the K7000 manual here:
http://arcarc.xmission.com/PDF_Monitors/Wells%20Gardner%20K7000%20Manual.pdf
It's laid out in there pretty well.
Generally red/blue adjust TO the green.
speedklz
Re: COnvergence
« Reply #2 on: November 13, 2009, 04:08:54 pm »
Dont tell me that.. THe red and blue are spot on but the green is shifted up just slightly, but enough to make it look bad.
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re: COnvergence
« Reply #3 on: November 13, 2009, 04:45:42 pm »
First, mark your rings with a marker in a straight line.  That way you can always return the rings back to their original position.
What I do is wiggle one slightly to see which color moves.  If its the wrong one, put it back and try the next.
Kevin Mullins
    • Me on Myspace
Re: COnvergence
« Reply #4 on: November 13, 2009, 05:15:44 pm »
Spot on in relationship to what ?  ;)
There are rings that move the red and blue collectively as a pair.
Is the difference consistent throughout the monitor screen or just one particular area ?
speedklz
Re: COnvergence
« Reply #5 on: November 14, 2009, 12:06:06 pm »
I use nokia monitor test for the convergence pattern and the blue and red on right but the green is shifted up slightly on all parts of the monitor.
