Main > Project Announcements
MAME Cab Black Nintendo -- Updated 13 feb. 2011: 1080i CRT TV
Epyx:
Out of curiousity you mention you used a local distributor. Do you mind passing along the name and cost? Im also in Canada and HD no longer carries the 4x8 sheets in Flat Black ($55). Other distributors supply 5x12 sheets at $130 or 4x8 at $80.
ptinolv:
I live in the region of Montreal. I got my formica from "Robert Bury Canada" and the prices were 75.9CA$+tx for the 5x12 and 40.48CA$+tx for the 4x8 (black). I sent an email to the company formica to know the local distributors and then i called them one by one to find the cheapest.
You can also try to check Reno Depot, they usually carry cheap 4x8 black sheets.
ptinolv:
We finally find a CRT TV high definition to replace the 480i TV (toshiba 27") of the cabinet. The new CRT TV is a Samsung 27" 1080i (model TXN2771HF). The difference is huge compared to the old TV. It required quite a bit of work, since the new TV is slightly larger. I had to file the board were the TV is inserted.
Here is some pictures i took with my camera :
emphatic:
Wow, I wish high res CRTs were available at ANY time here in Sweden. :o It looks amazing. :applaud:
jmike:
Well done :applaud:. That chrome T-molding really makes it pop. And I love that marquee (especially that gears of war cog with the gumba.
Question: what game is that guy with the green hair from? The one that has "Did you enjoy Dancing..."
