Main > Monitor/Video Forum
EDID Dongle... what is it and where can I get one?
ghostkiller:
--- Quote from: SailorSat on April 03, 2010, 02:30:03 pm ---Well I've came up with the whole EDID dongle thing because of a GF 8600GT refusing to boot into 15khz with the arcade screen attached, but running fine booting with my old Dell VGA screen :)
Until today I got every GeForce to work in 15kHz... At least in XP .)
An ArcadeVGA pretty much is the plug'n'play solution, however it also limits you in several ways.
That was pretty much my line of thinking as well, I didnt want to be limited to 15khz. By the way, im on vista 64 if that makes any difference. The arcadevga's are just regular ati cards bios flashed with firmware to force them into 15khz signals right?
SailorSat:
Well, Vista basically is the same sh!t as Seven, as both use the very same nvidia drivers.
In that case your better of with any Radeon based card, or an ArcadeVGA.
And yes, AVGA are just Radeon with special bios and drivers.
ghostkiller:
--- Quote from: SailorSat on April 03, 2010, 03:25:53 pm ---Well, Vista basically is the same sh!t as Seven, as both use the very same nvidia drivers.
My only question is if I end up needing a EDID dongle, where would I get one?
SailorSat:
You can get one from me.
ghostkiller:
--- Quote from: SailorSat on April 03, 2010, 04:53:58 pm ---You can get one from me.
ok then, monday when i get a chance to test things out i will let you know what I find. Thanks for your help.
