Main > Monitor/Video Forum
EDID Dongle... what is it and where can I get one?
Pages: << < (10/10)
Psykroro:
Hello,
Refreshing an old post for my 1rst one ;)
I just upgraded my MAME Sega New Astro City with a GTX 560Ti and it seems that now I need this dongle get it working  :banghead:
Did someone have one to sell me (the "official" one is a bit too expensive...) or could tell me how to do it myself (like how to program the 24LC22A) ?
Many thx for your help.
Psy
Darthbiker:
--- Quote from: SailorSat on July 30, 2013, 03:48:00 am ---Well VGA Pins 1, 2, 3, 5, 6, 7, 8, 9, 10, 13 and 14 are wired from the male to the female connector.
And VGA Pins 5, 9, 11, 12 and 14 are wired to the 24LC22A.
VGA 14 (VSync) -> IC 7 (VCLK)
VGA 15 (SCL) -> IC 6 (SCL)
VGA 12 (SDA) -> IC 5 (SDA)
VGA 09 (+5V) -> IC 8 (Vcc)
VGA 05 (GND) -> IC 4 (Vss)
files.arianchen.de/soft15khz/s15kedid.bin
Hola, estoy con el soft15khz en un retros xp y una grafica gtx650 nvidia, me aparece que necesito el dongle edid, he visto que tu lo puedes suministrar, necesitaria uno por favor, gracias de antemano.
Hi, I'm with the soft15khz in a retro xp and a gtx650 nvidia graphic, it appears to me that I need the edid dongle, I have seen that you can supply it, I would need one please, thanks in advance.
buttersoft:
There is almost zero chance a dongle will help with a GTX650, the bios and drivers are too new.
I would look into crt_emudriver and a compatible AMd/ATI card. The home for crt_emudriver is on these forums - http://forum.arcadecontrols.com/index.php/board,52.0.html
Using WinXP might make things tricky. you will need to use the older versions of crt_emudriver from version 1.2 backwards, and make sure you get a card listed for the driver you pick.
Pages: << < (10/10)
Go to full version
