Main > Project Announcements
killer instinct
<< < (4/5) > >>
Kevin Mullins:
--- Quote from: Beretta on September 06, 2009, 05:14:52 pm ---i assume he's gonna run ki 1 and 2 on mame in it, rather then a general use mame cabinet.
Sure..... a cabinet dedicated toward the KI series is cool.....
--- Quote from: Kevin Mullins on September 04, 2009, 03:48:04 pm ---I'd even go along with the multi-KI's others have built......but there's at least original hardware in those that I've seen. (JAMMA switchers)
Level42:
Just found out the reason for Killerinstinct's silence: He had an accident at work, fell 3 meters from a ladder and got hurt pretty bad. Not sure if he'll chime in here again, but he was able to leave a message at www.gameroom.eu telling this and said he will recover 100%.
So for now, the cab will have to wait...
SirPeale:
Holy crap!  I thought we scared him off.  Wishing him a speedy recovery!
killerinstinct:
hello
i'm back
i'm better now but i'l need a pretty long way to recover (i will)
sorry if i put this in the wrong section  ???
the pc is allready installed and an J-pac also , the controls are working
now the next thing i need to do is search how i'm going to do it with the monitor
if the arcade monitor is broken , then i'm going to look how i can put an normal tv in it
the pc that i'm using has an Svideo on board , is it possible to use that?
the last option is use vga scart but i'm not that smart to make such cable :)
will see
grtz
Beretta:
not sure where you are, scart is a european standard or what not.. anyway if your're in the states then no such luck no TV"s over here come iwth one.
you can also get scrat cables made if you dont think you cn make one.
in any other cases you can uses svideo although component will give a better picture if possible.
so yes your plan is very doable.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
