Author Topic: Proper counter wiring?  (Read 3372 times)
iscariot
  • Last login:April 02, 2025, 12:44:33 am
« on: June 12, 2009, 10:55:42 am »
I've got a coin counter I want to wire. How do I wire to both coin slots at once?
fatfingers
  • Last login:April 17, 2025, 05:26:08 pm
  • Got UltraStiks?™
Re: Proper counter wiring?
« Reply #1 on: June 12, 2009, 12:02:19 pm »
You will either need some diodes or an OR chip, I believe.
Good luck.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
W.W.P.M.D.?                                       I'm here to help ... I just don't do it. ™
whammoed
  • Last login:May 18, 2026, 01:07:35 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #2 on: June 12, 2009, 12:23:06 pm »
I believe it can be done with just diodes but you run the risk of running too much current through your encoder.  The safest way is with diodes and transistors.  I have set this up before (I had relays powering the counter but that is overkill...the circuit is basically the same though).  If no-one else posts a schematic, I can draw one up this weekend.
