Main > Main Forum
4 way joystick that doesnt need mounting plate?
<< < (3/3)
jakejake28:
--- Quote from: AlanS17 on July 04, 2003, 10:26:18 pm --- I can't speak for the Japanese sticks that they sell on the Ultimarc site. Those actually seem like they would work.
my j-sticks and e-stick are great for 4 and 8 way. the prob with the j-stick tho is the reach. it is too hard to hit the micro's in pac-man quick enough, luckily my e-stick resolves that problem
hulkster:
well ive already drilled all the holes in my cp today.  and its layout is 3 joysticks w/buttons across the cp.  i just drilled a regular hole for the super 8 that will be my 4 way joystick, so if i ever want to convert, then i can find a router some where and cut the square.  but i guess ill just have to settle for a while.  this is my first cab, so its not that big of a deal i guess.
J_K_M_A_N:
--- Quote from: DeafBug on July 04, 2003, 08:06:11 pm ---
I went over to Oscars and I can't find the price or part list for the mounting plate to order.  I did find this template
It is on the price and ordering info page. Scroll down about half way and it says "Joystick Mounting Plate". You have the option of Black Dimpled, primer or blank. Price of $15. Can't miss it. Good luck.
J_K_M_A_N
paigeoliver:
--- Quote from: hulkster081 on July 05, 2003, 12:36:55 am ---well ive already drilled all the holes in my cp today.  and its layout is 3 joysticks w/buttons across the cp.  i just drilled a regular hole for the super 8 that will be my 4 way joystick, so if i ever want to convert, then i can find a router some where and cut the square.  but i guess ill just have to settle for a while.  this is my first cab, so its not that big of a deal i guess.
Who needs a router or a jigsaw? I don't have either. I cut my square hole out using a freaking drill and a drill bit. I have done this multiple times in the past too.
Then put a piece of sheet metal over the hole. Install the stick to the sheet metal. I used a rather thick piece that I found laying around.
DeafBug:
--- Quote from: J_K_M_A_N on July 05, 2003, 11:23:30 am ---
Ahh!  Found it.  Thanks.  You actually have to shop to see it!  Any way to plug the extra holes as I only want it for the mspacman/galaxia joystick. Or are they not a factor?
J_K_M_A_N
Navigation
Message Index
Previous page
Go to full version
