Author Topic: Trying to build n64 arcade system, need help with control pad.  (Read 10117 times)
Chad.
  • Last login:August 25, 2010, 10:29:28 am
First let me start off by saying i'm new so hi, 2nd I know nothing about wiring or anything of this sort so give me a little break. Now what I'm wanting to do is create an arcade system with a n64 inside. As far as the buttons I wanted to know if I could change the buttons on a joystick I use now for my nintendo. [pics below] I wanted to replace those buttons with different buttons and then take the components out of the controller frame and place the compenents in the arcade system. [same with the joystick]
Replace them with these buttons:
Please and thanks for the help.
wooowman93
  • Last login:September 04, 2014, 03:56:02 pm
Re: Trying to build n64 arcade system, need help with control pad.
« Reply #1 on: April 19, 2009, 02:00:46 pm »
Just put a computer inside with n64 emulator why kill a real n64
OHH the HUMANITY
« Reply #2 on: April 20, 2009, 09:13:51 am »
OHH the HUMANITY
he killed a big ugly dokey 3rd party controller, whats the problem?
OP: what you need to do is solder wire to the lead and grounds of all the buttons and directions. most share a common ground but I cant see the PCB to tell you either way. Then run those wires to the buttons. Look up Haruman's 360 hack to get the general idea. If youre afraid or unable, Im sure he can do the N64 controllers for a reasonable price.
  • Last login:February 28, 2026, 04:55:22 pm
« Reply #3 on: April 20, 2009, 12:47:47 pm »
 :afro:
Chad.
« Reply #4 on: April 20, 2009, 02:45:37 pm »
:afro:
Is this true haruman? can you do this?
« Reply #5 on: April 20, 2009, 03:45:50 pm »
:afro:
I haven't seen that particular pad before, but I probably could.  I hack just about everything.   :cheers:
Chad.
« Reply #6 on: April 20, 2009, 05:24:54 pm »
:afro:
about how much would you charge? I'm guessing i'd send it to you?
« Reply #7 on: April 20, 2009, 07:08:55 pm »
For something like that, I would say $30, and yes, you would ship it to me.  The $30 includes priority shipping back to you.
Chad.
« Reply #8 on: April 20, 2009, 08:31:39 pm »
I messaged you. check your in box.
foleykoontz
  • Last login:November 11, 2020, 09:36:10 am
« Reply #9 on: April 21, 2009, 12:38:02 am »
I always wondered if there was such a thing as an N64 arcade stick, now I will never want to wonder again...
Arcadiac
  • Last login:April 14, 2020, 01:26:31 am
« Reply #10 on: April 21, 2009, 04:56:01 pm »
If I recall the coolest thing about that particular stick is that the center pad was analog!
ARCADIAC!
deadpool18
  • Last login:February 03, 2019, 04:22:48 pm
« Reply #11 on: May 04, 2009, 09:52:59 pm »
Hey Chad, don't let anyone discourage you.  This seems like a cool, unique project.
deadpool18
« Reply #12 on: May 04, 2009, 10:03:31 pm »
Hey, I have one of those Madcatz sticks.  I might be interested in having it hacked.  $30 sounds really reasonable.
Also, is it possible to hack the analog stick?  Has anyone tried to do this before?  I don't think I've ever seen a controller hack for any system where the analog stick was replaced with an arcade one.  Is it because the Happ sticks are ridiculously expensive?  Even so, how hard would it be to do?
deadpool18
« Reply #13 on: May 22, 2009, 11:03:31 am »
 :dizzy:
Ok, I think I undertand the whole hacking an analog stick issue.  It does seem impossible...
« Reply #14 on: May 22, 2009, 11:10:40 am »
:dizzy:
Yeah, hacking the analog stick is usually not possible.  Some controllers you can (like the official Dreamcast controller), but by hacking the analog stick, it becomes digitital (full on / off).
danny_galaga
  • Last login:Today at 08:13:07 pm
    • dans cocktail lounge
« Reply #15 on: May 23, 2009, 09:23:17 pm »
With that controller, it seems to me you would want to leave the analog as is, and somehow build that into your CP. Ya gotta have analog with the N64...
Bauley
  • Last login:December 08, 2012, 03:47:32 pm
« Reply #16 on: March 14, 2011, 09:30:10 am »
Sorry to bring this back from the dead  :dizzy:
Since this topic is approaching two years old...I was wondering if any progress has been made on hacking the analog stick?
I am hoping to one day build an N64 arcade cabinet using a hacked N64 controller. Has anyone yet managed to use a happ-style joystick to play N64 games?
Thanks in advance  :cheers:
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« Reply #17 on: March 14, 2011, 11:46:10 am »
This thread died for a reason ;)
The only n64 cab I can imagine would be more kiosk like than an actual cab, with 4 real n64 controllers held in place for players to approach and play.
SavannahLion
« Reply #18 on: March 14, 2011, 04:44:10 pm »
It is theoretically possible to hack the analog portion of the N64 stick. Unfortunately it isn't easy. Many N64 controllers are dying so someone constructed a pot to encoder adapter. The project, last I read, isn't suitable as a drop in replacement in the controller yet. But it can be adapted in some fashion to a pot based joystick to be used in an arcade setting.
The link is: http://nfggames.com/forum2/index.php?topic=3574.0
SavannahLion
« Reply #19 on: March 14, 2011, 07:05:26 pm »
Oops, I was thinking he didn't pack it in. He did get the pot stick in. That is all.
Mario
  • Last login:March 29, 2021, 08:55:12 pm
  • Mmmmm.....arcades!
    • Mario's Arcade Page
« Reply #20 on: March 16, 2011, 11:19:11 pm »
One solution is to use a computer with an N64 emulator and one of these joysticks. Expensive, but it may be worth it to an N64 fan.
Mario
TheSlim
  • Last login:September 27, 2015, 10:11:37 am
« Reply #21 on: March 30, 2011, 09:51:05 pm »
Here is some info on the N64 controller it should help with your hacking.
http://www.raphnet.net/electronique/gc_n64_usb/index_en.php
northerngames
  • Trade Count: (+18)
« Reply #22 on: March 31, 2011, 12:58:58 am »
that have the adaptiod's and knock's of that setup all over ebay in nice small case's with no tools required.
The OP wanted the controller functions to work using real arcade parts not so much getting a controller to work on the pc there's already plenty of premade/manufactured adapters for a controller to work on the PC.
