Author Topic: Gamepad mapping in mamewah/mame  (Read 1683 times)
jardine
  • Last login:May 12, 2025, 05:09:12 am
« on: January 23, 2009, 02:07:28 am »
3rd times a charm...can anyone please tell me how to get my GP Wiz40 working in mame v.125 and mamewah v1.63.
It is not recognising my joysticks or buttons...how can i get them working?
Windows recognises it as a gamepad but mame/mamewah is not. I have had a look through the wiki and am struggling to get my head around this one.
Please help  :banghead:
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Gamepad mapping in mamewah/mame
« Reply #1 on: January 23, 2009, 11:41:09 am »
You have to enable joystick for mame.  (Probably the same with mamewah if you want to use the GPwiz in the FE, but I don't use it.)
This is a FAQ in the mame FAQ.  It's probably the first bullet: just go into mame.ini, and set "joystick 1".  (If you don't have mame.ini file, use the command mame -cc to make one.)  If that is the only joystick type device, you'll be good to go.  If you have other joysticks also plugged in, your GPwiz might be the second (or higher) joystick, and controlling player 2 (or higher) with mame's default input mapping; this is the forth bullet in the above linked FAQ.  If this is the case, remap (also in the mame FAQ).
Robin
Knowledge is Power
jardine
« Reply #2 on: January 23, 2009, 06:04:43 pm »
This is why i can't beleive im so stuck...joystick is enabled in mame....when i try to go into the tab settings in a game i get no response outta my buttons/joysticks.
In gamepad options it show perfectly and even show it being mapped to the correct keys?? Am i missing something.
Zebidee
  • Last login:Yesterday at 07:02:45 pm
« Reply #3 on: January 27, 2009, 02:42:50 pm »
Check ALL your ini files: mame.ini, mame32.ini, and individual game ini files in the INI directory.
jardine
« Reply #4 on: January 27, 2009, 10:12:38 pm »
Cheers, found out that because i had compiled mame that i took away my mame.ini found in C:\mame.
Once i replaced it and set joysticks to 1 it worked. Been banging my head for ages and it was so simple.
Thanx 4 the help.
