Author Topic: Pac-man restoration - Return from Doh!  (Read 127820 times)
Spyridon
Re: Pac-man restoration - Return from Doh!
« Reply #160 on: August 02, 2009, 09:10:14 pm »
I sanded down the cab with 320 grit sandpaper then applied a second coat of paint.
Next color on the block = black
Level42
« Reply #161 on: August 03, 2009, 12:46:43 am »
I was always told to use a dark colored primer for dark (black) finishes because else the primer "shines through" ?
Guess an extra layer will probably fix it, but it's one of those "rules" you always hear.
WunderCade
« Reply #162 on: August 03, 2009, 12:54:55 am »
Black paint will cover white primer with no problems, and I think he is referring to the inside monitor area for the black.  The cab will be Yellow, which warrants using the white primer. He may even consider spraying another coat of primer with the yellow pigment in it to give the yellow top coats more depth.
Can't wait for the stenciling portion.
« Last Edit: August 03, 2009, 12:56:47 am by WunderCade »
Brogner
  • Last login:March 03, 2025, 12:58:08 am
  • If I could just get another quarter
« Reply #163 on: August 03, 2009, 02:27:41 am »
I've been away from this board for a long time.  I have to say this thread is something I will follow.
You are doing an awesome job on this and I will love to see how it comes out.  Maybe it will inspire me to get mine done.
Level42
« Reply #164 on: August 03, 2009, 05:26:48 am »
Hey, I'm very aware of how a Pac cab is colored, of course the black will only be on the inside monitor area, but he used the same primer there right ? :D
Spyridon
« Reply #165 on: August 03, 2009, 08:32:31 am »
Yes, same primer, but I'm not expecting to have a problem covering the white.  I've used black over white primer before and didn't have any issues.
ElGwako
  • Last login:September 24, 2011, 10:49:40 am
« Reply #166 on: August 03, 2009, 09:42:56 pm »
If you use the same color with a white primer and a grey primer....you will see a difference. The colors will be more true to color with a gray primer as opposed to a white. Even with 2 coats. Though you couldn't tell much unless you made the comparison.
I carry samples i made to prove this fact since plasterers that prime the walls for customers only use white primer. Also, a lot of pre-primed wood comes white(though i'm seeing it in gray now too). If a customer wants a burgundy wall. I usually insist on a gray prime coat first since it helps on coverage too.
looks like a good project. got me itching to do mine. If i can't get this paint off without ruining whats underneath of course
Mimatt
  • Last login:February 13, 2011, 11:59:28 pm
« Reply #167 on: August 03, 2009, 09:57:04 pm »
Looking for stencils, or the correct vector file to have stencils made myself, is beginning to get quite (the word "quite" being a large understatement) frustrating.  :banghead:
I've asked, and asked, and asked around until I'm blue in the face..
I'm seriously about to give up on my Pac-Man. It's been sitting here, for three years, waiting on a set of stencils. Hell, I bought paint stipper, and an orbital sander 6 months ago, and it's still sitting in my garage. The sander has yet to be opened.
SirPeale
  • Green Mountain Man
« Reply #168 on: August 04, 2009, 04:17:04 pm »
Hmmm...ask Jeff Rothe.
Spyridon
« Reply #169 on: August 05, 2009, 09:40:48 pm »
Started cleaning up the parts for the coin door.
Cleaned up the coin inserts with a wire wheel on the dremel.  Still need to polish them, but they look much better.
Front (before and after):
Back (before and after):
Also used the same technique on the bolts that hold these in place:
(before and after):
I finally opened the box that had the inner bezel that was shipped to me a while ago.  Wasn't expecting it to still have the plexi but it will be replaced anyway.  Needs some cleaning up and a coat of flat black paint.
Looks like the plexi is just held in place with double sided tape.
What's the best way to remove old (but still tacky) tape marks?  Goof off?  Goo Gone?
smalltownguy
  • Last login:February 13, 2023, 10:48:26 am
« Reply #170 on: August 05, 2009, 10:39:35 pm »
Start with Goo Gone. If that doesn't cut it, then you can try Goof Off. Watch out for Goof Off, though, it'll eat through all paint, most laquer, and many other types of finishes. It'll pit metal too, depending on the alloy. Tread lightly. It works though.
Spyridon
« Reply #171 on: August 08, 2009, 03:01:13 pm »
Started to clean up the coin mechs.  The coin return button is really in bad shape.  Any suggestion on best way to clean it?  I used the dremel on it, but doesn't look great.  I think I'm going to have to paint it.
Peale do you sell replacements of these?  It might be easier just to get a new one.
Spyridon
« Reply #172 on: August 08, 2009, 03:03:11 pm »
Did the next color paint today.
I'll check it out tomorrow when it's dry to see if I can get away with just one coat.
SirPeale
« Reply #173 on: August 08, 2009, 04:20:24 pm »
While mechs are fairly universal - though exceptions exist, of course - these are not.  Sorry man, you're stuck with them.  You may be able to polish them.  They were originally chromed.  Very few of the doors I've worked on in the last ten years had much chrome left on it.
Silas (son of Silas)
« Reply #174 on: August 08, 2009, 05:37:13 pm »
...Any suggestion on best way to clean it?
The clip below demonstrates using electrolysis on a cast item, but it works well on mild steel too. There are a stack of clips on youtube on how to do this, and the results are pretty amazing..
« Last Edit: August 08, 2009, 05:53:55 pm by Silas (son of Silas) »
My Project MAME clone
Who is Silas?
SirPeale
« Reply #175 on: August 08, 2009, 07:45:32 pm »
I have a lengthy thread in Arcade Misc regarding this.  I don't think it's right for this application, however.  Simple handwork will remove the existing rust easily, but won't do anything for the shine.
orion
« Reply #176 on: August 09, 2009, 12:45:41 am »
I'd try some of this stuff in the spray can variety http://www.liquidstainlesssteel.com/products.html Every midway coin return I have come across has been in a similar state. Your right, there is only so much you can do to clean those up with a dremmel and some polish.
Spyridon
« Reply #177 on: August 09, 2009, 11:29:17 am »
Looks like I'll have to clean it up and spray it.  That liquid stainless steel looks interesting.
Spyridon
getting ready for Yellow
« Reply #178 on: August 09, 2009, 01:47:26 pm »
Removed the masking.
Nice straight lines on the black
Next, I masked off the black
Spyridon
Yellow paint...Woot!
« Reply #179 on: August 09, 2009, 01:49:19 pm »
We've got YELLOW!!!!!!!
Applied the first coat of yellow today.  Nice and bright
« Reply #180 on: August 09, 2009, 02:19:27 pm »
looks great, been following this thread for a while now; one of my fave reads
WunderCade
« Reply #181 on: August 09, 2009, 02:35:15 pm »
That yellow looks nice.  Have you decided on when to apply the blue speckling?  There are not any blue specks within the actual artwork areas on the original paint job, so this tells me they either masked the artwork and speckled it, or the did it before they stenciled the artwork on the cab.
Spyridon
« Reply #182 on: August 09, 2009, 02:52:20 pm »
I'm planning on doing the blue speckles after the yellow and before using the stencils.
« Reply #183 on: August 09, 2009, 03:29:19 pm »
YELLOW!!! That's got to feel pretty good to see that going on? Thats a huge transformation. I'm a HUGE fan of yellow arcade machines  :applaud:
Who is Silas?
Spyridon
« Reply #184 on: August 09, 2009, 04:53:15 pm »
Yeah it does.  It's finally starting to look like Pac-man.  Maybe I'll just stop here and put it between two other games?    :laugh2:  NOT!
Spyridon
« Reply #185 on: August 15, 2009, 04:12:02 pm »
Second coat of yellow paint was applied today:
Spyridon
« Reply #186 on: August 16, 2009, 01:15:33 pm »
Coat number 3 of Yellow:
« Last Edit: October 19, 2009, 10:29:13 am by Spyridon »
WunderCade
« Reply #187 on: August 16, 2009, 07:26:06 pm »
Is that the final coat of yellow?  lol
I think we are all right there with ya about tackling the stencil.  But there's only one way to know....
Superully
  • Last login:October 06, 2016, 02:48:27 am
« Reply #188 on: August 17, 2009, 01:23:34 pm »
i'll be starting my pac-man restoration shortly and i'm curious to know how much paint you bought for each colour. could you give me something to work with, please?
i'm still struggling to find the correct colours, too. The colours on my twobits repro overlay are completely different from the one on my cab (blue and red are much darker on the overlay, yellow isn't that bright and "poppy"). did you match your colours to the cab's original colours or to the repro overlay?
Spyridon
« Reply #189 on: August 17, 2009, 02:37:30 pm »
I got the paint codes from someone on KLOV that had them computer matched.  I think he matched the yellow to the original cab and the other colors to the repro CPO (but I'm not sure).  I'll post the paint codes and sizes later in the week (I'm out of town on business right now)
Spyridon
« Reply #190 on: August 17, 2009, 02:39:41 pm »
What?  You guys don't like to see repeating pictures of yellow cabs?
I may do one more coat of yellow, because I have paint left.  I don't plan on doing another pac-man so I may as well use it.  I'll look over the cab later and see what it looks like.  If I can get time to paint on Thursday night, I'll add one more yellow.  No matter what, I will be painting the first stencil on Saturday!
Superully
« Reply #191 on: August 17, 2009, 03:15:21 pm »
problem is that you guys in the usa have other base colours than we europeans, so i guess the paint codes aren't of any use, or am i wrong here? can those american codes be applied to european base colours?
Spyridon
« Reply #192 on: August 18, 2009, 11:16:33 am »
Well, in this case, the paint I'm using is PPG automotive paint.  They may be international?
If it came down to it, I can facilitate shipping the paint to you (can you ship paint?), but then you are adding costs to what is already very expensive paint.
« Reply #193 on: August 21, 2009, 06:13:53 am »
...problem is that you guys in the usa have other base colours than we europeans, so i guess the paint codes aren't of any use, or am i wrong here? can those american codes be applied to european base colours?
I have had vehicle paints mixed for spraying really old cars many times in the UK. Its really common for the pigments to no longer be available or for pigments to be specified that were never available in the UK. Most dedicated paint suppliers can deal with that and can cross reference to those that are available.
You could use the American Auto paint codes to get a can of Nitro mixed up using European pigment equivalents, then spray a piece of steel, card or whatever that you could then take to somewhere like Homebase (in the UK, but I'm sure all countries have DIY stores that can do the same) and they would be able to colour match it and produce paint in whatever finish you require (low VOC gloss, eggshell, satin or whatever)
My MAME build will be finished with Formica Laminate in chrome yellow on the outside but the inside of the cab will be colour matched and painted in Dulux eggshell using the sample card of laminate supplied by Formica. Homebase can just as easily colour match an original colour of a cab if can get a sample. Getting the Auto paint mixed up seems like a long winded way of achieving this but at least its an option?
Who is Silas?
smalltownguy
« Reply #194 on: August 21, 2009, 07:35:59 am »
I work at an auto dealership that uses PPG. I'd bet that if you provided PPG with the paint codes, they'd be able to assist with matching for other methods.
Spyridon
« Reply #195 on: August 21, 2009, 08:23:52 am »
Here are the paint codes I used:
RED
M119 44.5
M154 205.0
M107 34.3
M118 0.3
M150 233.3
BLUE
M119 111.4
M121 79.2
M122 26.4
M117 10.2
M128 40.2
M150 266.3
YELLOW
M152 223.8
M119 34.8
M106 0.6
M118 0.6
M150 259.9
These are for OMNI AU MBC paint which is manufactured by PPG
Spyridon
« Reply #196 on: August 21, 2009, 02:48:52 pm »
I'm going to be starting the stencil process tomorrow and realized that I don't know the location of the artwork.  Can someone measure the location (distance from top, bottom, left, and right) for the sides and front.
Spyridon
« Reply #197 on: August 22, 2009, 09:01:46 am »
I just realized that I can't do the stencils yet.  I need to do the blue splatter first.
ZORK2
  • Last login:May 22, 2010, 11:45:04 pm
« Reply #198 on: August 22, 2009, 10:16:11 am »
NICE WORK MAN!! Looks GREAT!! Can't wait to see how the blue paint splatter turns out. Don't forget the top and back door were splattered with blue too! Looking forward to seeing how the stencils turn out!!
Spyridon
« Reply #199 on: August 22, 2009, 02:51:29 pm »
Blue splatter is done.
Tools needed: One new toothbrush
Dip the brush in the thinned paint and then flick the bristles to spray the blue paint.  Works great!  Just be sure to stand far enough away so that you don't drip on the cab.  You'll end up dripping a lot of paint straight down below your hand.
Not the easiest thing to photograph, but it looks really good in person.
