Main > Project Announcements
2 Projects...1 Bartop & 1 Pinball Countertop
punxrus:
Okay...so close...yet so far away! I was pretty successful this weekend with some stuff...however, none of it had to do with my cab. Instead of working on it, I managed to break my ankle which totally sucks. I do promise to get those pics of the cab up sometime this week as it's pretty much put together now. I just need to paint it and figure out how to run the power through the cabinet.
Franco B:
Ouch! Hope it doesn't slow you down too much.
To run power through the cabinet (if you mean what I think you do) you could use a flanged AC power inlet like this:
You can then just attach a 2/4way extension lead to the tabs inside the cab.
You can buy them from many electronics places or you can remove one from an old ATX PSU.
BobA:
Forget the ACT Labs light guns if you are using an LCD. They only work on monitors or TVs, depending on the model.
punxrus:
--- Quote from: Franco B on September 24, 2008, 02:04:17 am ---Ouch! Hope it doesn't slow you down too much.
That's what I'm looking for, just haven't found one here in the Olympia area of WA. I'll take a look online and see if I can pick one up. Everything else is going to run from the power supply to power the lcd monitor, speakers, marquee and etc. Once I'm on my feet that is...
punxrus:
Pics of the monitor installed...
Navigation
[0] Message Index
[*] Previous page
Go to full version
