Main > Project Announcements
paulscade - First Build - MAME - Blastoff!
Pages: << < (20/30) > >>
brock.sampson:
Just unscrew the pcb from the bottom of the u360 and rotate it so the up indicator is pointing up.
paulscade:
I didn't see anything on the U360 indicating "This Way UP".  Before I designed/cut-out the panel, I did plug in the stick to see which way was up but it happened over time (i.e. I received/checked the sticks some time ago... and more recently worked on the panel).
I did take the stick apart... and I used the mounting plate to trace out the shape onto the panel for routing.
I suppose that I just got caught up in the moment.
[recently acquired knowledge]
This stick is really versatile.... it doesn't matter which way that you mount it because you can adjust for mounting by rotating the PCB at the bottom of the stick.
javeryh: re: relaxing
Yea... I really do enjoy working on this project.  Unfortunately, most of the work was done in the garage... in Florida.... in the Summertime.   :o  I'm not complaining... but I must admit... now that it's all "inside work"... it's been much more relaxing.
Santoro:
Looking Good.   It's fun isn't it?
HairyDVD:
The wiring looks pretty good to me.  Looks like its gonna be a smart machine  ;)
Benevolance:
Paul, I wanted to give you a big thanks for doing such an incredible job documenting the build. I started my project just a little after you, and your project has certainly made my job a whole lot easier. Your cabinet looks great!
Go to full version
