Main > Project Announcements
New Jukebox - Wurlitzer style - Spring construction has begun!
Pages: << < (4/26) > >>
Namco:
Big Bubbles!
Singapura:
No small!
Singapura:
--- Quote ---found this while wasting some time this morning.  I submit for your viewing pleasure on this 4th of July:
Is there something like a hellcade for jukeboxes? That looks hideous  >:D
Ed_McCarron:
McCoy, if you haven't already thought of this...
Be sure that the feed air line is long enough to go up ABOVE the top of the bubbler tube and then loop down to the pump.  That way, if the pump shuts down, the water stays in the tube.
It only takes one failed flapper valve to make a wet mess on the floor.
mccoy178:
Good idea! :cheers:
--- Quote from: Singapura on July 04, 2008, 10:36:47 pm ---No small!
Is this a vote for small or big?
Go to full version
