Main > Project Announcements
New Jukebox - Wurlitzer style - Spring construction has begun!
yweiss:
--- Quote from: mccoy178 on January 03, 2009, 06:56:38 pm ---Update:
1. I found a good amount of this metal grill at a metal salvage yard. I was amazed when they rang up the 4' x 2' piece at a whopping $3.20. What a deal! So, I've attempted to clean it up and have put a coat of clear coat on it.
2. I mounted the secondary monitor to the corain. I used the same system from the last jukebox, the aluminum strap, but bent it at 90 degrees and predrilled my holes. The following pictures demonstrate nicely what I'm talking about:
3. I glued the shell together tonight in preparation for priming. I am excited to get this guy painted, I just don't know if I'm going to run out of time before school starts. :'(
Great build! where did you got thsoe aluminum strips? I want to mount my monitor also and it look a good way to do it
