Main > Main Forum
Help with painting issues
Pages: << < (2/2)
Frostillicus:
After the first coat of paint, I used a lot of very light coats, loading the roller maybe only twice per big side.  Sometimes just barely touching the roller to the wood - I'd go over the edge of the last stroke until it dissapeared, and when it dried it blended much better.
str1der:
Frost, I assume you were using a sponge roller.
Frostillicus:
--- Quote from: str1der on June 02, 2003, 11:02:09 am ---Frost, I assume you were using a sponge roller.
I guess - they are made by Shur-Line.  It says foam roller, which is sponge I assume.   This gave a smoother texture than the 'fine' fabric roller I used on my last cab.
Pages: << < (2/2)
Go to full version
