Main > Main Forum
Ultimarc joysticks
2slk:
In your case, I would say definitely centered. It would appear to allow more comfortable button access as well. Good luck!
CGRemakes:
Yea, I was definately leaning towards that as well for both the nastolgic "centered" feel, as well as easy access. Do you think it would make the CP look really off ballance, or should I off-set it a bit to make up for it? It might get more in the way of the player 1 buttons if I do though.
Tiger-Heli:
--- Quote from: CGRemakes on May 31, 2003, 03:22:18 pm ---Yea, I was definately leaning towards that as well for both the nastolgic "centered" feel, as well as easy access. Do you think it would make the CP look really off ballance, or should I off-set it a bit to make up for it? It might get more in the way of the player 1 buttons if I do though.
Definitely keep it centered side to side. Vertically, I wouldn't put it in line with the joysticks, but you could maybe move it up a tad.
CGRemakes:
More or less like this? (Sorry about the drawing)
Tiger-Heli:
--- Quote from: CGRemakes on May 31, 2003, 03:44:32 pm ---More or less like this? (Sorry about the drawing)
That's what I was thinking, but it's your panel!
