Main > Main Forum
Ultimarc joysticks
Brad Lee:
--- Quote from: Hoagie_one on June 06, 2003, 03:36:48 pm ---may need a slot cut at the center pivot as well
One or the other, but probably not both
Hoagie_one:
--- Quote from: Brad Lee on June 06, 2003, 03:51:13 pm ---
right, thats what i meant. Middle would be best idea becaus there may not be clearance at the joystick side
Brad Lee:
Now for the real wang-dang-doodle..
Ive got 2 sticks. You could shorten up the stick so that it ends inside the cabinet, use a long piece to run between the ends of the sticks, with some Kind of T in the middle.. have that stick out. If you get proper leverage, all of a sudden youre setting both joysticks for 4/8 at the same time, with one switch :o
Hoagie_one:
oooh, a mechanical genious in our midsts
lol
