Main > Main Forum
This will work?? PSX Converter DO ALL?
Pages: << < (4/4)
toilet:
Like that thread I pasted, you have to be concerned about what you're expecting from the converters. There are a lot of them out there, and many of them have quirks. Some don't work with non-analog PS1 pads. Some work with dual shock PS2 pads but not PS1's. Some work only when the contoller is in analog mode and not otherwise, or keep the dpad mapped to button presses as opposed to the axis when not in analog mode.
The lik-sang 'Boom' ones I know work properly with all pads and their modes. That is, when you switch the analog button on a PS1 Dual Shock / PS2 pad, the X-Y axis gets switched from the dpad to the analog stick.
If you're only gonna be plugging in PS2 Dual Shocks and using them in analog mode then most of the newer adadpters should be fine. Hope this helps.
edit: Oh, and you shouldn't need a floppy drive, if that's what you meant above. Under Win98SE-XP just plugging the USB adapter will bring up a '16 Button 4-axis Gamepad' in the game controllers control panel.
cleric:
But tell me whats BOOM converter MODEL ?? In lik-sang there are more than 1 model...
Check here and tell me plz :)
http://image.lik-sang.com/content/smartjoy/smartjoy_chart.htm
thanks
EDIT:
From this picture http://snake11417.tripod.com/sitebuildercontent/sitebuilderpictures/converters.jpg
I see he use TOTAL CONTROL for dreamcast. :)
But for the PC, i gone use the SUPER DUAL BOX (picture in reply above) but i see this thread is this forum it seen this guy  have some issues playing both 2 player on mame.
http://forum.lik-sang.com/showthread.php?s=&threadid=82
Can anyone tell if the Super Dual box is a crap or not ??
I dont want to spend money in something that dont work rigth.
toilet:
--- Quote from: cleric on May 29, 2003, 10:55:13 am ---But tell me whats BOOM converter MODEL ?? In lik-sang there are more than 1 model...
The 2nd one in (PS/PS2
cleric:
But hey, in the "Additional Notes"
they say  "Only compatible with analogue/Dual Shock controllers"
Do u have Dual Shocks hacks? function on analog mode?
Or digital mode?
Or non-analog psx ones?
EDIT:
The guy from that forum, say it resolve the problem. We must connect both psx pad, them connect to pc usb.
This Is great i will get one of this :)
Pages: << < (4/4)
Go to full version
