Author Topic: Ripping music from CD to mp3 files  (Read 8290 times)
unclet
« on: January 13, 2008, 09:18:26 am »
Is there a tool out there which will simply read the music CD I have inserted into my harddrive :P CDRom drive and then create a MP3 file for each song on there?
I am looking for something very easy to do this ......
« Last Edit: January 13, 2008, 03:41:34 pm by unclet »
polaris
  • veni vidi congai
Re: Ripping music from CD to mp3 files
« Reply #1 on: January 13, 2008, 09:23:28 am »
itunes?
« Reply #2 on: January 13, 2008, 09:32:38 am »
If you are using WinXP, Im pretty sure Windows Media Player 11 can be set to do this.
ideft
  • Last login:February 11, 2012, 04:06:09 pm
  • "Mister, I suspect you to be a dope fiend"
« Reply #3 on: January 13, 2008, 09:45:38 am »
WMP.
goto tools->options
click "Rip Music" tab
check the Rip CD when inserted
Orclord
  • Last login:October 16, 2009, 03:09:38 pm
« Reply #4 on: January 13, 2008, 09:49:42 am »
A lot of people use EAC + The Lame codec to get high quality rips, plus it gets the CD info via freedb and can tag your  mp3 as well........
http://www.exactaudiocopy.de/
It can take a bit of configuration though.......
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
« Reply #5 on: January 13, 2008, 11:14:28 am »
Itunes.
Just make sure you setup go into preferences-> advanced-> importing to set up the ripping the way you want. I.e MP3 quality and so on.
unclet
« Reply #6 on: January 13, 2008, 12:05:01 pm »
I have no idea what iTunes is  .....
I have Windows Media Player on my computer and when I rip the songs they get stored as .WMA files and not .MP3 files.   Is there a way to convert WMA to MP3 easily?
Sir Auros
  • Last login:December 06, 2012, 12:13:00 pm
    • The Transformers Archive
« Reply #7 on: January 13, 2008, 12:07:12 pm »
You should be able to tell WMP to convert to mp3 instead of wma. It's in the options/preferences somewhere.
Kevin Mullins
    • Me on Myspace
« Reply #8 on: January 13, 2008, 12:51:45 pm »
Check the options under the RIP tab......
unclet
« Reply #9 on: January 13, 2008, 12:54:45 pm »
Yes, I am an idiot for not seeing that ....... thanks   ::)
« Reply #10 on: January 13, 2008, 01:05:52 pm »
A quick note:  For older versions of Windows Media Player (prior to ver 11)
I downloaded and installed a plug-in by Cyberlink that will add the MP3 dropdown in the options menu in WMP.  It was only $9.95 and works great!
http://www.cyberlink.com/winxp_plugin/2007/enu/wmp.jsp
~ D
Kevin Mullins
    • Me on Myspace
« Reply #11 on: January 13, 2008, 01:13:52 pm »
Ha... I've been there done that.  :cheers:
The only other thing I should note is make sure you know WHERE they are being ripped.
(I did that one too, couldn't find the music once it finished ripping)
polaris
  • veni vidi congai
« Reply #12 on: January 13, 2008, 01:16:10 pm »
FYI iTunes is apples music player but it works on pc too.
quarterback
« Reply #13 on: January 13, 2008, 02:37:56 pm »
 :o
-- Chad Tower
Kevin Mullins
    • Me on Myspace
« Reply #14 on: January 13, 2008, 02:59:22 pm »
iTunes .....  :P
unclet
« Reply #15 on: January 13, 2008, 03:31:39 pm »
I figured it out .... thanks.
PS:  I still use a VCR ..... if that gives you any idea how quick I like to learn new things  .....  :P
« Last Edit: January 21, 2008, 09:16:59 am by unclet »
Level42
« Reply #16 on: January 13, 2008, 03:36:24 pm »
Yeah, I already wondered how you managed to get a CD into your harddrive.
:laugh2:
unclet
« Reply #17 on: January 13, 2008, 03:42:05 pm »
unclet < --  :dizzy:
GadgetGeek
  • Last login:July 09, 2024, 09:32:57 am
  • whatever
Kevin Mullins
    • Me on Myspace
« Reply #19 on: January 14, 2008, 08:45:40 pm »
Great write-up ..... if you are using Exact Audio Copy 0.9 beta 4.
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
« Reply #20 on: January 15, 2008, 08:02:05 am »
I have found with recent dvd-r drives little need for eac - I had to re-rip some stuff recently and even on burst mode in EAC I was getting the same CRC as when I ripped the same thing 4 or 5 years ago (dont ask about the need for re-ripping)
kizer
    • Links4jeeps.com
« Reply #21 on: January 16, 2008, 04:51:04 pm »
Ive used AudioGrabber for years and hasn't failed me yet.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #22 on: January 20, 2008, 01:38:35 pm »
.....so it doesn't work with other versions of EAC?
There's no need to use that specific version if you want, and quite frankly, the info on the exact version to use might be outdated by now, but it'd be nice if it doesn't work with other versions of EAC if folks would say something so we could UPDATE a STICKY!  ::)
Better yet, why wouldn't someone ELSE do a write-up on OTHER ways to do this?  I'm not EVER using WMP or iTunes, either for ripping OR playing, because I prefer to use my music in the manner I choose, and Windows AND Apple have both chosen to DRM the music I PAID FOR as their default.
Seriously, someone do a writeup on how to get NON-DRM files using iTunes or WMP.  Otherwise, you are all doing people a disservice by giving simple drive-by advice on programs WITHOUT including that one little piece of advice on disabling that "feature" ::)
richms
  • s92a sucks
    • richms.com
« Reply #23 on: January 20, 2008, 09:25:42 pm »
Itunes doesnt drm what you rip, and wmp doesnt either - there was a tickbox you had to change back in the 7 or 8 days to get it to do no drm, I dont know if that setting has just carried across the upgrades or if the new ones just dont do it at all since my userprofile has moved between all my installations of windows
cripto9t
  • Last login:January 31, 2008, 10:30:30 am
« Reply #24 on: January 21, 2008, 12:45:06 pm »
Me to. I've ripped all mine and alot of my friends cds without any problems.
http://www.audiograbber.com-us.net/
_- cripto9t -_
MPTech
  • Last login:January 05, 2025, 03:58:54 pm
  • UltimateArcade completed!
« Reply #25 on: February 14, 2008, 02:57:41 am »
I second EAC!
I've Ripped hundreds of CDs with it and it's GREAT and from the reviews I read, it's one of THE best. (in fact, I'm ripping 2 CDs on 2 PCs with it right now.
No complaints.
MPTech
   Better living thru technology!   ;-)
govee
  • Last login:February 19, 2012, 09:26:30 pm
« Reply #26 on: February 14, 2008, 11:51:28 am »
Another vote for AudioGrabber.
kreed
  • Newbie
  • Last login:February 21, 2008, 07:55:59 am
« Reply #27 on: February 21, 2008, 07:55:59 am »
i always use WM Player it allows to convert from music CD to mp3's and save to drive
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #28 on: February 22, 2008, 04:16:26 pm »
The write-up in that link still works for current versions of EAC, but the recommended version of lame is very out of date.
'Best' version is 3.97 now, it superceeds the old 3.90.. dibroms/tweaked versions. This may require a change to the compression settings that are entered into EAC, not sure.
More info:
 http://www.hydrogenaudio.org/forums/index.php?showtopic=28124
pmc
  • Last login:February 07, 2026, 12:21:50 pm
    • website
« Reply #29 on: March 05, 2008, 12:55:11 pm »
Yeah.... after 3.90 they changed the standard for LAME's flags from something like "--alt-preset standard" to "--preset standard" or "-V2". The new system is better but the old documentation still floats around making things confusing sometimes.
Personally I've used EAC since 1999 or so but I only use it to rip. For some reason I trigger an encode with LAME via CDEX. I guess I'm just slow to change what's already working for me.
I'd really like to switch to Ogg Vorbis but it smacks of effort. :)
-pmc
