Main > Software Forum
CPWizard v2.63 Released
Pages: << < (127/145) > >>
jasonbar:
Howdy headkaze-
I'm revisiting CPWizard after several years.
I'm using 2.21 on my MAME cabinet.
I just downloaded 2.39.
What's the most elegant means of updating CPWizard without losing my settings, layout, etc. That is, can I just copy over the newer CPWizard.exe file into my current installation? Ought I copy any other files too?
Thank you,
-Jason
headkaze:
--- Quote from: jasonbar on October 09, 2013, 03:23:23 pm ---What's the most elegant means of updating CPWizard without losing my settings, layout, etc. That is, can I just copy over the newer CPWizard.exe file into my current installation? Ought I copy any other files too?
Sorry for the late reply. You should be able to install CPWizard without it effecting any of your settings or layouts although I would backup your CPWizard Data folder just in case.
greggooch:
Sorry, I created a new thread for this a moment ago but just realized this thread might be the best place for this question.
I am trying to get Layout Mappings to work for CPWizard, where a "constant" such as lightgun, dial, or trackball would bring up a different layout than the default.  The problem I am having is that the sub screen only loads if there is no mapping.  I can get games like Tempest or World Class Bowling Deluxe to display the sub screen only if I uncheck the box in the CPWizard mapping section, but it displays the default mapping in that case.
I have tried reinstalling CPWizard (backing up my CPWizard config folder first), rebooting, and it still does not work even with the default settings from the installer.  I have tried mapping with "Control" vs. "Constant" and even tried both.
I should also mention that the preview tool in CPWizard itself displays the correct layout with no problem.  This is just when I am trying to get it to work with MAME.
knightrdrx:
it just showed up at game launch without me even finishing setting it up...then i did something and i don't see it anymore (i tried to design my own layout) but regardless..i had to exit manually ...couldn't it just show up for 10 seconds and then the game title screen comes up?
If not I think I'd rather have it on the pause setting if i cian figure that out.
jaharr01:
Hey I was wondering is there any way to get CPwizard to work with a GGG GP40 controller without using joy2key?
Go to full version
