Main > Software Forum
CPWizard v2.63 Released
Marak:
Here are some more you can use if you want to.
These are the Sanwa JLW Joysticks with the colored bubble tops.
headkaze:
Thanks Marak I will be including them in the next release :)
TheShanMan: I think I figured out why Mame was no unpausing using CPWizard. I know it's a bit late now that your using the bezels but I bet it will work now. First thing I just realised is the bezel patch has been broken the last few releases I missed out the part which will actually unpause Mame. Also I realised you need the "Send Pause Key" option set under Edit->Options->Mame as well. So there are two reasons there which probably explain why it wasn't working for you.
I've uploaded a new bezel_0127.zip if you interested.
TheShanMan:
I will try it! There are definitely advantages and disadvantages with bezels and with live CPW overlays, so I'm looking forward to trying it live again.
TheShanMan:
Well I gave it a try tonight and it works great!!! :cheers: I think I may switch back to the "live" cpw for now and see if I want to stick with it, after being used to bezels for a while. 2 minor visual problems I noticed though: I see the mouse cursor when the cp is up even though I have the option to hide it checked. And sometimes I see the minimized mame window on top of the cp. Since I don't have explorer.exe running there is no taskbar to minimize to, so you get a small rectangle at the bottom when minimized. Sometimes it is on top of the cp, and sometimes it's not.
headkaze:
TheShanMan: That's great news! I'm really happy it's finally working for you. There are problems with Windows being on top especially with no taskbar as you've discovered they minimize into a small Window. I spent *alot* of time working on dealing with Mame when it has two windows open and had to some some special stuff to get that working. At the same time I figured out ways of dealing with Mame minimizing and maximizing better, so in the end it's a much more solid program. I will probably have to do another big debugging session like that to deal with all these other issues with windows minimizing without the taskbar present and such.
