Main > Software Forum
CPWizard v2.63 Released
Pages: << < (35/145) > >>
Curatio:
--- Quote from: headkaze on May 05, 2008, 08:13:40 pm ---Make sure you install the latest version from the website before you copy over the exe. This exe is not an official release and it uses new components only available inside the version for download. If you check your log file you will probably see an error which is why CPWizard is exiting.
Thanks, headkaze! I installed the latest version, then copied over the exe, and now it is working great. I even recompiled my Mame 0118 with the bezel diff, and now the Send Pause Key feature works perfectly too. Great work!
jhabers:
Suggestion for a feature that would be very helpful to me. I know you can set the "back" key to exit out of CPWizard, but can you make an option so it also un-pauses the game as well when you do this? So basically exiting out of CPWizrd will exit and unpause the game.
TheShanMan:
That feature already exists, but for recent versions of mame you need to apply his mame source code patch and build mame yourself so that mame will listen for CPWizard's request to unpause.
jhabers:
--- Quote from: TheShanMan on May 06, 2008, 01:24:16 pm ---That feature already exists, but for recent versions of mame you need to apply his mame source code patch and build mame yourself so that mame will listen for CPWizard's request to unpause.
wow, dont know how i missed that, I am running mame .123, and chance that the bezel124 patch will work on my mame .123. I would go to mame124 but my roms are 123. Any advice?
Jon
jhabers:
--- Quote from: jhabers on May 06, 2008, 05:36:48 pm ---
Jon
the 124 diff seemed to apply to 123 source with no errors, compiling now
Go to full version
