Main > Main Forum
Lighted Buttons - Per Game
Pages: << < (7/8) > >>
DinoRoger:
I will look into this idea.  Currently I only have 8 or 4 way joysticks, but will purchase a switchable one soon.  Any recommendations on which one is the best purchase to attempt this?
shmokes:
I think you should get the E-stick so you can consider making it change between regular and diagonal (q-bert, congo bongo) as well as between 4-way & 8-way.
Xiaou2:
 On the note of Selenoids (actuators)... I think it would be great if someone could make and sell a Terminator2  and other gun Kickback coil system.
jrshenk:
shmokes, The only problem with changing from regular to diagional with the E-Stick is that the whole joystick assembly must be rotated by 45 degrees not just the restrictor plate cam. Since the E-Stick uses a threaded body, similar to the way a button to mounts, the nut can be loosened and the assembly rotated. That is why it says the "switch plate" can be rotated for games like Qbert. But this process of loosening the nut and rotating the whole joystick then retightening the nut is not very easy to automate. To change from 4-way to 8-way we only have to rotate the cam on the back of the switch plate. Happ controls makes a joy stick alomost identical to the E-Stick. Happ calls it the universal and they have an exploited view on their website. You can get a better idea of what I mean from looking at that drawing.
1UP:
This is a great idea!  However, I can think of a way you'd need more than 8 LEDs: Space Invaders and Asteroids.  Both these games use buttons rather than a joystick for directional controls, and the buttons are used by both hands.  Asteroids uses the player 1 buttons for left and right, and the player 2 buttons for thrust, fire, and hyperspace.  So you might want at least 12 independent LEDs.
As for a T2 recoil output solution, I'm still working on it!  ;)
--- Quote from: jrshenk on May 11, 2003, 02:55:54 pm ---shmokes, The only problem with changing from regular to diagional with the E-Stick is that the whole joystick assembly must be rotated by 45 degrees not just the restrictor plate cam. Since the E-Stick uses a threaded body, similar to the way a button to mounts, the nut can be loosened and the assembly rotated. That is why it says the "switch plate" can be rotated for games like Qbert.
I think we're getting confused here again...although it's possible to do so, the E-stick DOES NOT have to be externally rotated, and the mounting ring does NOT have to be loosened to go from straight to diagonal!!!  In fact, it was not designed that way at all.  Anyone who has an e-stick can check this out.  Try this: grasp the top mounting plate FIRMLY, and twist the bottom switch plate (the whole thing, not just the restrictor plate dummy.)  Whadya know? it rotates about 45 degrees!  I cant believe that everyone with an e-stick still doesn't know how it's supposed to work...  :P
Look at what you just wrote: "That is why it says the "switch plate" can be rotated for games like Qbert."  Yes, the SWITCH PLATE, not the MOUNTING PLATE.  The switch plate is the plate with the microswitches on it, on the bottom of the whole joystick assembly; in other words, it's the plate that the restrictor plate itself is mounted on.  It is not the plate that mounts above the CP -- this mounting plate is intended to stay locked tight to the CP at all times.  Note the mounting hole pictured at the bottom of the diagram above.  The hole has two small notches to either side.  These are obviously intended to mate with the two round protrusions on either side of the e-stick's threaded shaft, thus keeping the stick locked in place.  The switch plate, however, is mounted on the threaded shaft in such a way that it can be rotated around the shaft from below, like so:
So it would be quite possible to have a system of automatically switching straight to diagonal by some kind of motor etc, while the joystick remains securely mounted to the CP.  It may be harder to come up with a system of automatically switching both the switchplate AND the restrictor plate independently though....
Go to full version
