Main > Main Forum
LEDs in coin door
SirPeale:
--- Quote from: TazMan on May 07, 2003, 01:54:29 pm ---Yep - that is as long as the original socket is T 3 1/4 - which is what Happ uses as default for their coin doors and Illuminated push buttons, which by the way I switched the incandesent bulbs with these leds also. I actually just used the one bulb T 3/14 leds from them for the pushbuttons
They're not Happs coin doors. One's a Williams coin door, the other two are from CoinCo.
KevSteele:
Very cool! Thanks for the URL -- I may just swap out my current LED setup for socketed LED lamps.
Kevin
