Author Topic: Push button connector size  (Read 10729 times)
Hawk Daddy
  • Last login:June 15, 2025, 03:10:44 pm
  • Only True Pimps Have Arcade Machines!!!
« on: September 17, 2007, 03:29:13 am »
What size connector do i need for happ push buttons I'm talking about the little terminal connectors.
They look like this
Also where can I order some in bulk like around 200-500?
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
Steel Talons 2 player helicopter game
DrFrag
  • Last login:December 15, 2011, 10:14:47 am
    • MAME Cab Worklog
Re: Push button connector size
« Reply #1 on: September 17, 2007, 05:14:41 am »
4.8mm connectors will fit, if you're using metric gear.
I think they're called Tab Connectors or Quick Release Connectors, if that helps your searches.
« Last Edit: September 17, 2007, 05:16:46 am by DrFrag »
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
« Reply #2 on: September 17, 2007, 05:44:45 am »
6,4mm universal - fit terminal 4,8/6,4
Happ use 4,8 mm
ultimarc use 6,4 mm
sanwa/seimitsu 2,8mm
crown/korea 4,8mm
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
« Reply #3 on: September 17, 2007, 09:44:49 am »
The tab on the microswitches is .187.  The color of the crimp connector is dependant on the gauge of wire you are using
16-22 Red
14-16 Blue
10-12 Yellow
I was able to find .187 disconnects at my local hardware store.  Divemaster sells these http://forum.arcadecontrols.com/index.php?topic=47066.0 100 for $5.99.  Bob Roberts also sells them http://www.therealbobroberts.net/conectas.html 50 for $5.00.
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #4 on: September 17, 2007, 11:39:30 am »
It depends on the switch.  It can be .250 as well.
