Main > Linux
gentoo / advancemame fresh install
Pages: << < (8/9) > >>
Major Rock Hardy:
@wires: a low pixel clock is what you need to be able to do in order to get old 15.7 kHz frequencies to your arcade monitor for the authentic resolutions
@Tilzs: I wondered about that.  It was easy enough to get a hold of 1.9.19, so I just did that.  Compiling was not so easy but I've documented it here.  A thorough look through the source code would tell us whether the patches were necessary for 1.9.25.  I did not look.
wIrEs:
what if i use a PC monitor and a HDTV ?
i noticed today that some games dont run in full screen mode on my monitor but run in a normal window. Should i set my monitor to resolution 800x640 to play all the games ? i am currrently at 1280x1024, i am just testing the games on my desktop pc before building a cab.
Tilzs:
It sounds like you are using SDL, in X. Major Rock Hardy and I are discussing patches for svgalib. svgalib and fb run from console.  I haven't really run advancemame in X, but if you post your advmame.rc, we can probably figure it out.
whammoed:
--- Quote from: Major Rock Hardy on August 29, 2007, 11:24:27 pm ---
Line 366 was this:
--- Code: ---bool generic::load_info(game_set& gar);
--- End code ---
make it this:
--- End code ---
Great!  I always bookmark your threads.
But...ummm...what is the difference between those two lines?  Am I missing something?
Major Rock Hardy:
 oooh, good catch whammoed!  I dunno  :dunno what happened there - bad copy/paste I guess.  This is now fixed above.  The problem was the
--- Quote ---bool generic::load_info(game_set& gar);
part (in red)
thanks for catching that.
Go to full version
