Author Topic: Question About HAPP Trackball and Grounding??  (Read 1706 times)
lettuce
  • Make It So!
« on: July 21, 2007, 09:59:21 am »
On the Happ trackballs you have a large green wire with a mounting hoop on the end which is for ground the trackball, i guess for static build up??, Is it ok to ground this wire to the trackball mounting frame??
lettuce
  • Make It So!
Re: Question About HAPP Trackball and Grounding??
« Reply #1 on: July 21, 2007, 04:43:25 pm »
Anyone?
miles2912
« Reply #2 on: July 21, 2007, 04:46:48 pm »
On my MAME cab I just removed the wire and I don't use it.  Been working fine for over a year.
falkensmaze
  • Last login:February 27, 2024, 03:11:34 pm
  • No I wouldn't prefer a nice game of chess!!
« Reply #3 on: July 21, 2007, 05:27:37 pm »
I just cut the loop off and put them in a spare ground in my opti pac but i guess any ground would do. And yes it is for static build up so i guess its worth doing.
http://www.ultimarc.com/optipac3.html
p's The x  and Y axis were reversed with me( as oposed to above web site instructions)  for some reason maybe happ changed the design sightly..
« Last Edit: July 21, 2007, 05:30:07 pm by falkensmaze »
Theres no way you can win? There is always a way!!
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
« Reply #4 on: July 21, 2007, 08:38:31 pm »
It's my understanding that it's indeed to prevent static buildup, but not for the usual purpose (protecting electronics).  It's to prevent dirt/dust buildup in the assy. to help prevent wear.  Hook it up!
If I do not respond to your post in a timely manner, feel free to PM me.
TOK
  • The Game Always Wins
« Reply #5 on: July 21, 2007, 09:03:41 pm »
I ran it to the lug which was the common ground for my sticks, buttons and IPAC.
My panel is on it's third iteration now, with the trackball plate countersunk, but I previously had it exposed and the trackball plate would often give you a static shock if the ground was disconnected. Not a big deal, but the common ground made that go away.
