Main > Main Forum
RE: New Addition to Tornado Spinner Line!
Pages: << < (5/5)
u_rebelscum:
--- Quote from: Tiger-Heli on April 21, 2003, 08:39:45 am ---
--- Quote ---Hall effect joystick - Road Runner, I-Robot, Escape from the Planet of the Robot Monsters.
Assume these are like the P360's and a standard joystick will work fine.
A standard joy will work, but an analog joystick will work much better.
Hall Effect tm joysticks are analog joysticks that use magnets instead of mechanical POTs.
--- Quote ---720 degrees (not mentioned) spinner with a handle and calibration wheels - can be played using a standard spinner or standard 8-way depending on MAME build.
Or an analog joystick in analog+.  Better than with an 8-way any day of the week.  (BTW, you can dl the analog+ source and just use src/drivers/atarisy2.c if you want to compile your own mame with this 720 feature and not all the other analog+ stuff.)
Pages: << < (5/5)
Go to full version
